Replacing original batery - RK2706
Old 18th Dec 2008, 6:49 am
Default Replacing original batery - RK2706
Hi guys
I'd like to know if some of you have tried to change the original battery of RK2706? My mp5 has an battery with the same voltage and size of nokia's mobile phone since those batteries used in our mp5 don't work for so long, I think it would worth a try to change. What do you think?
:roll:
Old 18th Dec 2008, 10:17 am
I readed in this forum that someone replaced the original battery with an ipod nano one and get double playing time with is mp3 player. Can't remenber who this was. Just check the voltage, the allowed place (to dont buy a too big battery) and then the more mA you'll have, the more playing time you'll get. That's what i understood. Wait for getting confirmation from a more experienced person than me
Old 18th Dec 2008, 10:30 am
Hi
I did a how-to that might be of some help, it's for a generic rockchip but the principle is the same
http://www.mympxplayer.org/rockchip-...ap-vt6745.html
Old 23rd Mar 2009, 8:48 pm
You can fit any battery that will physically fit in the case. Provided it is one cell only (3.7 volt nominal). But there's the possibility that the charging circuit is hardwired for the capacity (mAh) of the original and putting in a larger battery could confuse it.
Probably the charger doesn't have that much intelligence so the only effect would be longer charge time.
If you change the battery just be careful about avoiding shorts. Lithium batteries sometimes respond to abuse by blowing up.
Replacing to all new firmware kingmax General Discussion 1 25th May 2009 3:59 pm
Batery problem! The Hitman Support and How To 3 21st Apr 2009 7:09 pm
Need help replacing battery... DeltaFX Support and How To 7 30th Nov 2007 8:36 am
Replacing Battery cv1 Support and How To 4 22nd Dec 2006 5:15 pm
Broken screen, needs replacing myschyf Support and How To 4 22nd Nov 2006 6:34 pm
