-   -   auxiliary cable (double ended 3.5mm) for use in car (http://mympx.org/forum/general-discussion/42964-auxiliary-cable-double-ended-3-5mm-use-car.html)
Lorne 12th Jan 2009 7:41 pm
I have searched far and wide through the internet (mostly hong kong sites).
I was having difficulty finding an aux cable (double ended 3.5mm cable) for use in my car.
All i want is cheap with preferably free shipping.
If you can direct me I will be forever greatful.
Thanks!
admin 13th Jan 2009 12:46 am
Re: auxiliary cable
[html:063eac6a4b]
I found mine at a local electronics store. Or a store that sells Hi-Fi systems.
<br \><br \>
Since you are in Canada, I found the following on eBay as well:
<br \><br \>
<script src='http://adn.ebay.com/files/js/min/ebay_activeContent-min.js'></script>
<script src='http://adn.ebay.com/cb?programId=7&campId=5335920029&toolId=10026&keyw ord=aux+cable&catId=293&width=470&height=400&font= 4&textColor=333366&linkColor=333333&arrowColor=8BB C01&color1=B5B5B5&color2=FFFFFF'></script>
<br \><br \>
Hope that's of help.
[/html:063eac6a4b]
Lorne 13th Jan 2009 3:33 am
Thank you sir
May I suggest an updated avatar
I have been staring at that one for over 3 years now
admin 14th Jan 2009 1:57 am
Originally Posted by Lorne";p=&quot (Post 56093)
....May I suggest an updated avatar
LOL!
Good point.
I'm going to update soon as I have some more MP4 players to add to the collection :).
