HIGH CAPACITY CARDS (8gb)
Old 18th Jan 2009, 9:14 pm
Default HIGH CAPACITY CARDS (8gb)
Hello all,
I have a 2.8" Touch Screen 8gb mp4 player (rockchip) - Version : 01.09.0051 - Just like this one ->> http://cgi.ebay.com.au/2-8-TFT-8GB-MP3-MP4-Player-touch-screen-ROCK-PG5-08GD_W0QQitemZ300287296148QQcmdZViewItemQQptZLH_De faultDomain_15?hash=item300287296148&_trksid=p3286 .c0.m14&_trkparms=72:975|66:2|65:12|39:1|240:1318
I bought a 8gb HC mini sd card that is recognized by the mp4, however the data on the 8gb HC card is not visible.
Is there any way to get the MP4 to work with that 8gb HC card?????
Old 20th Jan 2009, 2:09 am
Try to format it with FAT32, that's the right filesystem for such large capacity card.
Also, are you pretty sure that the player supports SDHC cards, and that yours is truly a 8gb one?
With a bunch of MP4 players for repair... and none will be mine , now that''s bad luck.
Annying high frequent sound from MP5 player mac_gyver General Discussion 0 19th Jan 2009 10:14 am
which memory cards can you use on the onda vx878? GefilTefish General Discussion 8 30th Jan 2008 1:06 pm
Can Disk Utilities be used 2 remove Memory Cards Hack? ashley_rb Support and How To 1 5th Jan 2008 3:30 am
MiniSD slot won't read cards chevrofreak Support and How To 0 2nd Nov 2007 1:03 pm
Memory Cards for Mp3, Mp4, Psp, mobile phones etc dadou23 General Discussion 3 21st Aug 2007 5:15 am
