Hooray!!! Rockchip SDK!
Like Tree1Likes
  #91 (permalink)
Old 12th Mar 2009, 9:26 am
My player is compatible with the Ramos T8 and I was able to flash it with the T8 firmware (its called Shoktec x5005) but that model sadly doesnt support rkp-games. Btw, has somebody verified that this firmware for rk2706 does support rkp-games? I havent yet found anything in the source that looks like a rkp-loader. I think the games are part of the firmware ("/application/game/gameselect.c").
WIZARD, I dont know of any decompiler that would produce actuall c-code thats close to the original source nor have I tried to use one (I was replying to a similar question before in this thread). I once read that there exists a "decompiler" for the apple iphone which is based on ARM too but couldnt find a download, there also seems to be a "Decompiler" plugin for IDA. Im using arm-elf-objdump -D -m arm -b binary <file>(assuming youre using windows) to disassemble code, but thats asm not c.
  #92 (permalink)
Old 12th Mar 2009, 11:41 am
WIZARD's Avatar
Default Re: Hooray!!! Rockchip SDK!
However, it would be easier to compile another parts of Rockchip SDK to get the full SDK
than trying to remake the Apple SDK.
Maybe you should take some elements from RK26XX firmware,
and then try to port. I think it's possible. :P
Try to play !
  #93 (permalink)
Old 12th Mar 2009, 12:39 pm
Maybe you misunderstood me WIZARD, I wasnt talking about an Apple SDK at all and I dont see any reason to port parts of the RK26xx SDK.
In my opinion the first step has to be to run some own code on the device and that doesnt seem to be an easy task to me atm. If that has been achieved one can easyly dump the whole internal memory space to a file or install a custom bootloader.
Regards Ale
  #94 (permalink)
Old 12th Mar 2009, 2:00 pm
i tried to compile the emulator today again but it asked for debug.h i dindnt have! i created one and now im getting many errors in source code!
BTW: HELP ME WIN A MIZU M8 AND FOLLOW THE INSTRUCTIONS IN MY SIGNATURE!
Help me win a Meizu M8 register and press the red button under my picture on http://sjbbs.zol.com.cn/1/980_104.html
Audio&Video : OS-43
  #95 (permalink)
Old 13th Mar 2009, 2:47 am
I think i once compiled the r7dll vc-project and changed the output from .dll to .exe and indeed it compiled and ran but it didnt show up any window only some text on the console about initializing different things and then repeatedly an error message.
initio() (DUMMY)
Enter Main!
Sys Disk Writable[0]User Disk Writable[0]OS Task Switch Error!OS Task Switch Error!OS Task Switch Error!OS Task Switch Error!OS Task Switch Error!
The problem was that there is no source for this specific code, its part of the precompiled stuff in iSource.o/iGlobals.o..., I dont remeber that exactly. Btw, i didnt get many errors but only a few with the other messages just being warnings about using deprecated string functions etc..
Regards
  #96 (permalink)
Old 14th Mar 2009, 10:18 am
WIZARD's Avatar
Sorry. There was my silly question... ops:
Try to play !
  #97 (permalink)
Old 14th Mar 2009, 10:42 am
WIZARD
Look at this:-
http://mympxplayer.org/2-vt10186.htm...=asc&&start=15
wiRe was working on an extractor for Rockchip!
  #98 (permalink)
Old 15th Mar 2009, 5:08 am
WIZARD's Avatar
I think that it's not finished.
Also this program could damage my firmware, and I don't have a backup.
Knob, if you have a backup for your player, then test, please! :roll:
I'll try Acronis, maybe it can do backup for the hidden partitions.
Link to sources of the Rockchip Extractor is HERE
Link about SDK is HERE
Try to play !
  #99 (permalink)
Old 15th Mar 2009, 12:02 pm
I tried to compile it but It isn't complete enough to compile, not sure how the extractor was intended to work.
It would be easier if it ran as a rkp application, then no problems with getting into Rockusb mode, but such an extractor would only work for players with a game menu.
  #100 (permalink)
Old 16th Mar 2009, 6:35 am
WIZARD's Avatar
As I know, all the RK26xx-based players have the game menu.
RK27xx doesn't have, however, there's an application for this purpose.
So, the fact that RK27xx haven't the game menu doesn't make sense!
Try to play !
