Hooray!!! Rockchip SDK!
Like Tree1Likes
  #101 (permalink)
Old 16th Mar 2009, 7:55 am
on my nationite OS-43 which is a rk2708 player its possible to access the hidden partition by copying a file called rkusb.tag to the root of my memory! then i have to reconnect it via usb and i can access the firmware partition and can access the APPDATA, RESOURCE, SYSTEM and so on folders! maybe it works on yours too?!
Help me win a Meizu M8 register and press the red button under my picture on http://sjbbs.zol.com.cn/1/980_104.html
Audio&Video : OS-43
  #102 (permalink)
Old 16th Mar 2009, 8:02 am
Originally Posted by WIZARD";p=&quot View Post
As I know, all the RK26xx-based players have the game menu.
RK27xx doesn't have, however, there's an application for this purpose.
So, the fact that RK27xx haven't the game menu doesn't make sense!
no
some 26 series have game but no game menu so can not access and pick specific game, it just loads a game by defaullt, player with game menu go to a screen first where you can select a game
some 27 series player have game menu, but not many, the s:flo has a firmware with games menu but its an old one, others do to like vx787 etc etc
  #103 (permalink)
Old 16th Mar 2009, 12:53 pm
WIZARD's Avatar
Default Re: Hooray!!! Rockchip SDK!
No it's not possible to do the same thing with RK26xx,
because they're different. :cry: :cry: :cry:
Try to play !
  #104 (permalink)
Old 17th Mar 2009, 9:22 am
WIZARD's Avatar
Something interesting...
http://group.zol.com.cn/12/19_111270.html
Try to play !
  #105 (permalink)
Old 18th Mar 2009, 9:01 pm
I was able to find the download link to the program if you would like me to upload it, please tell me here. It seems like it would be for the 27 series only but i dont know.
  #106 (permalink)
Old 19th Mar 2009, 12:04 pm
Can someone download this? :-
http://translate.google.com/translat...hl=en&ie=UTF-8
  #107 (permalink)
Old 19th Mar 2009, 4:21 pm
Originally Posted by knob";p=&quot View Post
link
http://www.sendspace.com/file/m1nh82
1. Access to USB devices which are driven to obtain the information.
2. Read device version of it is to read device's firmware version and the version of boot code.
3. To obtain the version of the document I have not test out the usefulness of its functions.
4. To obtain disk information access to the machine it is the information storage capacity.
5. RKUSB switch to the status it is useful to put the machine to switch to direct repair status of the USB drive, this function is very useful, replacing the repair 拆机 upgrade troubles.
6. Upgrade features I have not test out the usefulness of its functions.
7. Delete is the Safely Remove Hardware equipment.
8.MSC types of unknown function.
9. See system disk goes without saying that this feature is very useful function, it can be directly transferred out of the machine drive system, which will help us to repair the internal firmware upgrade, and extraction of the original machine's firmware file.
10. Output OUTPUT should be understood as a direct export firmware files, but I did not test out.
  #108 (permalink)
Old 20th Mar 2009, 3:42 am
WIZARD's Avatar
What I can do with this program?
Can I backup the firmware from my RK26xx? :roll:
EDIT: Look at the http://www.mpnbbs.com/ -
It's the home site from this screenshot.
Maybe there're some another programs...
Please, click HERE.
Try to play !
  #109 (permalink)
Old 20th Mar 2009, 2:36 pm
Default RockChip extractor
WIZARD
Look at this:-
http://mympxplayer.org/2-vt10186.htm...=asc&&start=15
wiRe was working on an extractor for Rockchip!
I was also working on an extractor, I did look at Wire's code, although it was similer to my own.
Wire says he did manage to extract the first few bytes, but my code seems to fail when reading the firmware from the player.
The extractor can find the Player, and access the player, only the reading of the firmware needs a look at.
If anyone wants the Delphi source to this, and maybe run a fresh pair of eyes over it, then get in touch (PM), I will release as freeware should we ever get it working.
Dancemammal
  #110 (permalink)
Old 22nd Mar 2009, 12:53 pm
Here is RKPlayer that I just started on, it's just a demo for now:-
http://www.sendspace.com/file/fon6xz
