Hooray!!! Rockchip SDK!
Like Tree1Likes
  #111 (permalink)
Old 23rd Mar 2009, 9:04 pm
Hey Wizard:
Can I have some of whatever you're on?
  #112 (permalink)
Old 24th Mar 2009, 6:04 am
WIZARD's Avatar
Default Re: Hooray!!! Rockchip SDK!
Interesting. I have ran threw the code. :shock:
Maybe it'll grow to a cool program for Rockchips! :P
Want to test this sample program, e.g. the navigation. (the only thing it can)
However, I don't know how to compile the .out file. :roll:
Try to play !
  #113 (permalink)
Old 24th Mar 2009, 10:44 am
It's easy to compile, just open config "player.ini"
in FWTools and hit the compiler button to compile "RKPlayer.out"
  #114 (permalink)
Old 24th Mar 2009, 12:03 pm
WIZARD's Avatar
However, after I've launched the compiled .rkp with icon,
I saw the black screen, and after a few clicks
there was a picture for 0.1 second (maybe exit.bmp) and then the exit.
Unfortunately, I have a lot of homework, :cry:
and will be unavailable to develop anything for a long term,
was lucky to complete the new version of Gilraen,
because must prepare for the big tests. :roll:
Have some of time only for launching something compiled,
and compile the source code, but not for something more difficult.
Can you launch it on your player, and see the pictures?
Was hardware configuration SDRAM 0x16bit & CPU 48 MHz,
or another? LCD size = 320x240 ? Orientation = X axis?
If your settings were different, please tell me,
maybe my settings were wrong
and that's why I have some problems.
Try to play !
  #115 (permalink)
Old 24th Mar 2009, 12:43 pm
Here are the settings:-
no SDRAM setting.
  #116 (permalink)
Old 25th Mar 2009, 7:18 am
WIZARD's Avatar
Don't know why I had the problems,
because was compiling with the same settings
(if SDRAM is default, then it is 0)
However, I have compiled again, and now it's working!
Strange, because the size in bytes for old and new files was the same! :roll:
After I've pressed the >|| button when music selected,
saw the black window with the border. Good.
But I can't go to settings:
while the <key> button, the program will exit.
P.S. Guys, have you downloaded the new version of Gilraen HERE ?
A lot of new features, create the awesome, nice and spooky styles,
and save them to the settings file... :P
Try to play !
  #117 (permalink)
Old 1st Apr 2009, 5:04 am
WIZARD's Avatar
Have you any news?
Try to play !
  #118 (permalink)
Old 2nd Apr 2009, 1:50 am
Well, so far I wrote a tool that lets me include code into the existing firmware or create a new firmware file from some binary code. I also did a little research on the firmware of my player and could identify some functions. Actually I wasnt able to do sth useful except for verifying that my code actually gets executed and fried the player twice. Happily I was able to repair it using the RK27 Device Manager. Well, thats it.
  #119 (permalink)
Old 4th Apr 2009, 10:30 am
hi AleMaxx
That's good. have you finished the tool yet?
Could you upload it someplace, I have a couple of base.rkw files I would like to merge but need something to fix the checksum with.
  #120 (permalink)
Old 4th Apr 2009, 6:18 pm
Yes, its more or less finished. I uploaded it here together with a little bit of documentation. I dont give any guarantee though that it works as expected, check the output with IDA or some disassembler of your choice. It cannot repair checksums, but that could be added if needed. What do you mean by merging btw, knob?
Regards
