Hooray!!! Rockchip SDK!
Like Tree1Likes
  #131 (permalink)
Old 14th Apr 2009, 2:55 pm
Default Re: Hooray!!! Rockchip SDK!
@knob, and did you modify the code to make it work or did it work without changing
  #132 (permalink)
Old 15th Apr 2009, 12:49 am
knob, did you try to run the rk27 firmware on the player? does it work?
  #133 (permalink)
Old 15th Apr 2009, 2:36 am
knob, на какой e-mail высылать?
  #134 (permalink)
Old 15th Apr 2009, 2:41 am
Всем привет /Hi all!
Thanks timon for password
в архиве SDK_1.08_Release.rar находятся:
- FWTools 3.0 - улучшенная версия
- Source code of rk2606, with images
- pdf document
- chinese ReadMe
Компилируется без ошибок, но файл *.out или *.rfw я не нашел в папке build (скомпилированный материал должен сохраняться в папку build)
  #135 (permalink)
Old 15th Apr 2009, 4:48 am
WIZARD's Avatar
Please, somebody, post the password here, or send it to me:
QJZQQJZQ3@yahoo.com
Try to play !
  #136 (permalink)
Old 15th Apr 2009, 4:56 am
got it
  #137 (permalink)
Old 15th Apr 2009, 9:51 am
WIZARD's Avatar
The password is : ttee . :mrgreen:
Try to play !
  #138 (permalink)
Old 15th Apr 2009, 10:48 am
Thanks for the password. :wink:
Here's a translation of the SDK release notes.
First, increase the file header Note:
1) Add all the module's source file and header file first, the end of the Notes, the Notes in the document to add amendments to records
2) Add all the function of the first Notes
Second, e-books Update:
1) e-book update, to speed up the browsing speed, bookmarks to 9, more than nine books to share bookmarks.
2) resource file "bookmarks extract floating window. Bmp" need to be amended to remove the No. bookmark, displayed by the program show 1-9.
Third, modify the system scheduling module code
1) update the ScheduleModule.c function ProgramSchedule1Module and ProgramSchedule2Module, can save the system code.
2) document the various MsgDef.h scheduling module need to define the module ID in the code ID (XXX_CODE_MODULE_NUM).
Fourth, WAV decoder update
Support for PCM, MSADPCM, IMAADPAM playback of music files. WAVDecode need to update the directory database files and WAV files.
V. Resource Management Update
The Resource Manager code and part of the data assigned to Module II, to reduce the system program and data space of the occupied space.
1) The need to revise all the Explorer code;
2) modify each module "to return to resource manager" code (for example, the music player menu button a short press to deal with);
3) system call function to delete the code BrowserDirInit, resource management system code is not permanent, it can not be deployed.
Sixth, using the new script file LCF link
1) to amend the code is basically no need to amend the script file, all modules of the space allocation is dynamic.
2) a new script file for FWTOOLS 3.00 above, the old version does not support it.
7, modified encoding Encode
1) increase the file write-back function, support the MediaPlayer can play audio files.
Eight, update USB File System
1) to increase the speed of USB news
2) to solve the problem: When the characters in the path containing '\' (such as Traditional consultation) may be caused by file not found, may cause a serious crash.
3) an increase of low-level format in FAT32 format, the first time after firmware upgrade to open the opportunity to spend 3-4 seconds.
9, NO SDRAM updating the AVI codec
The relative effect of a video version of a very good improvement
AviDecode_NOSDRAM need to modify the code directory and library file
RKAVI220X176_NOSDRAM.A.
Note: When the hardware does not use SDRAM, the SDRAM control must be related to short the P2.10 and P2.11, or else the video will cause abnormal operation.
10, part of the solution product information model to view the issue of death
Treasury updated RKSYS.A and documents SetMenuSchedule.c function DispCopyRightFunc.
11, added support for APE file format;
12, added to FLAC format support;
  #139 (permalink)
Old 15th Apr 2009, 2:02 pm
whn i install the fwtools it closes because i need a lisence?
  #140 (permalink)
Old 15th Apr 2009, 2:14 pm
The licence is in this download:-
http://mympxplayer.org/rockchip-gdk-...it-df1003.html
