Hooray!!! Rockchip SDK!
Like Tree1Likes
  #141 (permalink)
Old 20th Apr 2009, 1:00 pm
Default Re: Hooray!!! Rockchip SDK!
Been testing out the rk2606 sourcecode on my player.
Looking at the Lcd settings here is what I've been doing with PowerOnLcdinit()
__attribute__((section(".sys_init_text,\"ax\"")))
void PowerOnLcdinit()// lcd settings when you first power on. Where the white screen problems and
//reversed display problems originate.
LCD_Reg_Set(0x0001,0x001B);//knob orig good
//LCD_Reg_Set(0x0001,0x011b);//knob reverses and inverts display!
LCD_Reg_Set(0x0002,0x0700);
LCD_Reg_Set(0x0003,0x7030);//knob orig good
//LCD_Reg_Set(0x0003,0x7055);//knob mixes display up!
//LCD_Reg_Set(0x0003,0x7100);//knob reverses display!
//LCD_Reg_Set(0x0003,0x8000);//knob makes white screen
LCD_Reg_Set(0x0007,0x0137);
LCD_Reg_Set(0x0008,0x0004);
LCD_Reg_Set(0x0010,0x4040);
LCD_Reg_Set(0x0011,0x0002);
//LCD_Reg_Set(0x0012,0x081d);//knob contrast too dark
LCD_Reg_Set(0x0012,0x0811);//knob display contrast ok
//LCD_Reg_Set(0x0012,0x0809);//knob contrast very high
//LCD_Reg_Set(0x0012,0x0800);//knob contrast increased too high!
LCD_Reg_Set(0x0013,0x3509);
LCD_Reg_Set(0x0021,0x0000);
LCD_Reg_Set(0x0030,0x0000);
LCD_Reg_Set(0x0031,0x0502);
LCD_Reg_Set(0x0032,0x0106);
LCD_Reg_Set(0x0033,0x0301);
LCD_Reg_Set(0x0034,0x0206);
LCD_Reg_Set(0x0035,0x0605);
LCD_Reg_Set(0x0036,0x0707);
LCD_Reg_Set(0x0037,0x0103);
LCD_Reg_Set(0x0038,0x0000);
LCD_Reg_Set(0x0039,0x0000);
LCD_Reg_Set(0x0040,0x0000);
LCD_Reg_Set(0x0041,0x0000);
LCD_Reg_Set(0x0042,0xEF00);
LCD_Reg_Set(0x0043,0x0000);
LCD_Reg_Set(0x0044,0xaf00);
LCD_Reg_Set(0x0045,0xef00);
LCD_Reg_Set(0x000b,0x8000);
Found the settings that affect the Contrast, And the Lcd reversal problem.
After playing around got the display looking pretty good now. :wink:
Need to look at the button settings a bit to try and get that in order, but the firmware is already usable on my player, I can navigate and play Mp3s and everything else seems to work as it should. :wink:
When I do a bit more work on the source and put more comments in I will upload it.
I am trying to see it anything can be done to help users who have lost their firmware and comment in the source the bits you need to tweak.
If anyone else want to have a play please bear in mind you must have a working backup firmware or you risk bricking your player and this firmware is only good for 2" rk2606 Rockchips with standard buttons, not touchscreens.
  #142 (permalink)
Old 21st Apr 2009, 12:50 pm
KNOB, we need your build-skills for the rk27xx too!!! I would happily convert whatever comes out there into a BASE.RKW. Anyway great work, keep it up & hang on.
  #143 (permalink)
Old 22nd Apr 2009, 12:41 am
WIZARD's Avatar
Any news about the firmware extractor for rk26xx ? :roll:
Try to play !
  #144 (permalink)
Old 27th Apr 2009, 3:06 pm
More firmware source code, this time complete for Rk2608 players!
RK2608_4G_DEMO Rockchip Micro firmware source code, the version, add text, pictures, aut SCM www.pudn.com
and a powerpoint tutorial for Rk26xx :-
RK26XX-chip-introduce This a speech coding relevant information right mp3/mp4 program design usef Communic www.pudn.com
download here too:-
http://www.sendspace.com/file/k467x8
  #145 (permalink)
Old 28th Apr 2009, 1:05 am
i have have an account there, if anyone wants it pm me
  #146 (permalink)
Old 29th Apr 2009, 7:13 am
i have new fwtools version 3.1.12.0! you have this already!?
Help me win a Meizu M8 register and press the red button under my picture on http://sjbbs.zol.com.cn/1/980_104.html
Audio&Video : OS-43
  #147 (permalink)
Old 29th Apr 2009, 10:31 am
hi Benjy
No we don't have this version.
Can you please post a link or upload it someplace.?
The rk2608 firm doesn't compile with the older version, maybe 3.1.12.0 will work.
  #148 (permalink)
Old 2nd May 2009, 7:46 am
Been looking at fixing the button arrangement on the RK2606 firmware:-
case KEY_VAL_UP_DOWN://knob Increases Volume in Music Screen
MusicDisplayBlock.DisplayFlag.bit.bVol = 1;
OutputVolumeInc();//knob Increases Volume in Music Screen
break;
case KEY_VAL_MENU_SHORT_UP://knob Decreases Volume in Music Screen
OutputVolumeDec();//knob Decreases Volume in Music Screen
break;
  #149 (permalink)
Old 2nd May 2009, 5:14 pm
Sir can you help me??? i need firmware for my mp3 player with specification:
CHIP: HYNIX HY27UT088G2M
ATJ 2091 N
BOARD: MP3-910639 V:3
THANKS BEFORE
  #150 (permalink)
Old 4th May 2009, 1:33 pm
Hi benjy
Can you send me the fwtools 3.1.12.0 or tell me where to get them. By the way can it dump from 2608a chipset?
regards
Rob Oudendijk
