Hooray!!! Rockchip SDK!
Like Tree1Likes
  #361 (permalink)
Old 1st Oct 2009, 10:58 am
sid6581's Avatar
Despite that it's nice to see that the thread is so alive ;-)
I think it is a little bit "too alive". It is very difficult to navigate thru this very long thread.
Is there anything we can do do make it more efficient.
Could we create a special sections for developers in the forums and have independent threads there ?
Rockchip Powah !
  #362 (permalink)
Old 1st Oct 2009, 11:36 am
Just disabled the RTC on my player, it doesn't support it anyway.
It was causing a pulsing lockup sometimes when I plug in the usb cord. <-- not true, I had messed up the build, gone back to a previous build now ops:
Of course it makes the calender redundant now, but hey we could swop that for something else.
Here's what I got now in Hw_define.h
#define INTERNAL_RTC 0
#define PT7C4337 1
#define HYM8563 2
#define RTC_TYPE INTERNAL_RTC//knob
Still need to fix the audio though, hey flasher can you post how you disassembled with IDA pro, I had a try but the output didn't look right, used the setting embedded Rom image btw.
  #363 (permalink)
Old 1st Oct 2009, 12:00 pm
here's screenshot which AleMaxx sent to me. You click new > embed > rom > base.rkw > ARM (the first one on the list) > values from screenshot below > goto address 0x60000000 > press C to convert binary to ASM code.
BTW. Not the whole code will be displayed, it requires to trace the correct address of the function and press C for convertion.
  #364 (permalink)
Old 1st Oct 2009, 1:12 pm
Here's a signature file for RK27XX. Basically I just took every file from RK27SDK_NEW\Library\ARM.
MEGAUPLOAD - The leading online storage and file delivery service
  #365 (permalink)
Old 2nd Oct 2009, 4:04 am
RK2708 datasheet:
  #366 (permalink)
Old 3rd Oct 2009, 7:47 am
Had a another look at the keypad configuration. The RAmos 970 is the most like the one i am using
tried to define it but I couldn't get a successful build.
#define KEY_TYPE Rm970key//knob
  #367 (permalink)
Old 3rd Oct 2009, 11:18 am
sid6581's Avatar
We can chat on IRC :
server: irc.freenode.net
channel: #rockchip
See you all very soon
Rockchip Powah !
  #368 (permalink)
Old 3rd Oct 2009, 12:42 pm
sid6581's Avatar
I am searching for the DSP (ZSP400) compiler ? I have seen some ZSP400 source code in the SDK but it is precompiled.
I am kind of worried that we cannot write any ZSP400 code
Rockchip Powah !
  #369 (permalink)
Old 4th Oct 2009, 2:57 am
WIZARD's Avatar
Wink
Realview includes the ZSP Compiler (I think so check if I'm right)
Download this archive, and follow the instruction
This link was deleted
Try to play !
  #370 (permalink)
Old 4th Oct 2009, 10:43 am
Here you can order a demo version of ZSP compiler by Verisilicon:
Verisilicon Tools License Manager
