Hooray!!! Rockchip SDK!
Like Tree1Likes
  #501 (permalink)
Old 31st Jan 2010, 3:17 am
New video player or dissasembler? ;-)
Maybe there is a source code for Acme V-500X,
Ver: 22.02.2008, Date: 2008-05-21.
Some video player settings are just annoying.
  #502 (permalink)
Old 20th Feb 2010, 1:14 pm
Hello! Could anybody upload RK2606 SDK? I meen sources for firmware. All links that I see there already don't work.. Or you can send it to me by e-mail.
  #503 (permalink)
Old 20th Feb 2010, 1:59 pm
WIZARD's Avatar
@mmlevin
Download links:
Rockchip SDK - Working Links
Try to play !
  #504 (permalink)
Old 20th Feb 2010, 11:19 pm
@wizard
Thank you, I've already downloaded Rockchip Developer Files and found Rockchip GDK, sources for some games, FWTools, but I can't find firmware sources anywhere In this thread I founded some links, so now I have sources for RK27SDK_NEW and RK2608_4G_DEMO (probably old version, as I see in sources it have no support for FLAC format). But sources for firmware RK2606 I can't find anywhere.
  #505 (permalink)
Old 24th Mar 2010, 8:55 am
WIZARD's Avatar
Exclamation sig11
It seems that sig11 have mysteriously disappeared
No response to my E-mails and PMs
No sig11's Rockchip Emulator
Try to play !
  #506 (permalink)
Old 24th Mar 2010, 1:02 pm
Wink
mmlevin
Sources for Rk2606 uploaded here:-
http://www.sendspace.com/file/dy5789
NEW thread for Rock game porting is here:-
Porting "Rock" Games, Is it worth it now?
  #507 (permalink)
Old 26th Mar 2010, 11:04 am
Hello everybody. I had a long break from working on anything connected with mp4 players due to my college staff, but now I will have a lot of time to mess around the topic, esspecially with theming tool I mentioned in another thread.
Anyway, WIZARD asked me to upload the source code of FM radio app because its not available anymore, so here it is:
FM_Radio.rar
  #508 (permalink)
Old 27th Mar 2010, 1:31 pm
WIZARD's Avatar
Wink
Thank you, Flasher! Rockchip SDK archive gets an update.
P.S. I will not have time for the development until Summer.
New Gilraen with graphic interface (it will be easier and faster to create the subtitles than now, using command line)
and maybe some new Rockchip games and updates for the old ones (it's possible to fix the Calculator's bug)
Try to play !
  #509 (permalink)
Old 11th Apr 2010, 7:21 am
I am just wondering...
There is a variable called Language in the RKP platform. It gives information about a language which is set in the system settings of the player. But are the numbers representatives always the same for a particular language, or is it different for each model of mp4? If is the same for all of them it would be helpful to develop multilingual apps with automatic detection of the language.
So is it worth messing around it? what do you think?
  #510 (permalink)
Old 11th Apr 2010, 2:20 pm
hi flash
It should work. There is a utility to convert the text resources and they have multiple languages in.
A problem I can see is working out all the translations! and deciding how many translations to do!
If would be better if we had file loading support for .rkp, then the language file could be loaded in by the app and easily edited by the user as a simple .txt file.
If we provide the sources the users can do their own translations anyway, so it IS probably not worth it.
