Hooray!!! Rockchip SDK!
Like Tree1Likes
  #541 (permalink)
Old 22nd Apr 2010, 1:10 pm
oh maan. It works now!! It can access SDCard while being executed from flash! If only we had access to flash memory we could even transfer files between these two drives.
Also, it runs so much faster if run from flash! Awesome, you re good. Maybe you have some ideas about flash memory then?
I tried. I can read pages from the flash, but I do not know structure of the flash drive ( numeration of sectors , begin of the FAT , e.t.c).
This function is reading page from flash ( I have hy27uu08ag5m , but it is the common command for all NAND-flash ):
void readPage(unsigned int col,unsigned long row)
int i;
write_mem(FLASH0_CMD,0x0);
write_mem(FLASH0_ADDR,col & 0xFF);
write_mem(FLASH0_ADDR,(col >> 8) & 0x0F);
write_mem(FLASH0_ADDR,row & 0xFF );
write_mem(FLASH0_ADDR,(row >> 8) & 0xFF);
write_mem(FLASH0_ADDR,(row >> 16) & 0x03);
write_mem(FLASH0_CMD,0x30);
printf("\n");
for ( i = 0; i < 2112; i++ ) {
buff[i] = read_mem(FLASH0_DATA);
The first page that I have read from flash was a part of firmare with some offset.
  #542 (permalink)
Old 24th Apr 2010, 9:53 am
Wow, its great! You're genius!
  #543 (permalink)
Old 25th Apr 2010, 12:35 am
WIZARD's Avatar
Exclamation Awesome
New breakthrough!
  #544 (permalink)
Old 25th Apr 2010, 9:03 am
Break on through to the other side! Nice!
This is rk26xx related, isnt it?
  #545 (permalink)
Old 25th Apr 2010, 9:41 am
I used that function to read flash data, it works, though I had some problems. When I set up the FatFS lib for this, it showed me some weird filenames in the root dir (sometimes I get those names even with embed explorer, which needs a restart or reformat of the drive). Also we need to figure out where the offset of flash drive is written. I wrote a function which scans flash mem looking for fat file system, though it took 15 minutes to find it - getting through 14mb of FW data.
Yes, right.
EDIT:
Small piece of work regarding open dialog.
SD_Card.rar
look how extremely fast it draws graphics.
  #546 (permalink)
Old 28th Apr 2010, 7:29 am
WIZARD's Avatar
15 min of waiting - every time when you want to open/save the file
Though, it's better than nothing!
EDIT:
This open dialog is nice! However, I can't open anything
  #547 (permalink)
Old 28th Apr 2010, 10:30 am
Yeah, its incomplete.
Coming back to this flash memory. Is there someone who knows where in the FW data the total FW size is coded? it must be somewhere, like this tool for creating themes for rk26 knows exactly where bmp resources begin in the RKW file.
  #548 (permalink)
Old 28th Apr 2010, 10:45 am
This is nice work, flash.
sig11 has done a file manager too.
try looking at the source from dancemammal editor, it's in delphi.
http://mympxplayer.org/dancemammal-m...030-df882.html
  #549 (permalink)
Old 28th Apr 2010, 11:12 am
I'll check it, thanks.
BTW. Do you know how to hack memory flash in rk27? I still got one of these with one 4gb chip broken. I got 4gb of usable capacity while other 4 is dump space. How to format it to appear to be 4gb partition instead of 8gb? Those guys from ebay did that so it must be possible.
  #550 (permalink)
Old 29th Apr 2010, 4:50 am
Never had the memory hack problem myself.
Someone here has fixed a Rockchip memory hack:-
[Tut] hwo to remove memory-hack on Rockchip Mp4-players.
but not sure which version it refers too.
btw have you had issues with do,while() and printf() with the rk26xx Sdk/Gdk?
I've been looking at porting again and had some problems with bugs in the SDK.
