Hooray!!! Rockchip SDK!
Like Tree1Likes
  #601 (permalink)
Old 14th Aug 2010, 3:25 am
Hm... In my case, sound is normal, but not so loud as in original firmware (about 50%) and with "hr-hr-hr" instead of Basses. And if I try to play *.ogg file, it plays, but then screen is off (by timeout), player hangs up and does not response on keypress or touch, only reset helps.
Maybe we can patch file browser to associate, for example, *.pdf with reader? (again, it's not my idea, it's already implemented for siemens). Single elf (daemon) will handle such associations.
I think we don't need special library for pictures (pnglib) and patch for writing strings that elfloader on Siemens has, but at my opinion would be nice if we will have icons in toolbar. By default, in toolbar only clock and battery, and most place is empty
  #602 (permalink)
Old 14th Aug 2010, 3:31 am
flasher86, I'm slow You guessed that I want to suggest
  #603 (permalink)
Old 14th Aug 2010, 3:02 pm
Hey,
I have a archos 43vision
This player - clone of Ramos T8 - has the following characteristics:
Screen
10.1 cm 4.3 inch, TFT, Touch Screen, 16:9, WQVGA screen
Chip
RK2706 chip
Resolution
480 × 272 pixels
Memory
8 GB flash + micro SD card slot
Music
MP3, FLAC, WMA, APE, WAV s
Videos
RM / RMVB, FLV, AVI s
Photos
JPG, BMP, PNG
Other
Text Files
Batteriey
1500mAh Li-ion y
Autonomy
15 Hours
Connectivity
USB2.0/Sortie TV (cable not included)
His chip RK2706 you will - if the mood takes you - to modify the interface of your player!
firmware I have is this one:
http://translate.google.fr/translate...s-43-vision%2F
there are a lot of bug: stop the aircraft in full viewing, listening to music etc. ...
it is an img file that you can decompress with sudo mount-o loop ~ / Bureau/Archos43.img ~ / Desktop / iso
I wonder if I use another firmware than my mp3/mp4 is what will work.
and I would like to know how to do to create its firmware (more precisely, have the doc's most comprehensive study of RK2706B for source code) because I want to get into programming.
  #604 (permalink)
Old 15th Aug 2010, 1:20 am
If you want your own firmware, you can compile rk27sdk. Try to find in this theme link to Deposit's folder that contains all documents and sources. You can download my package, there is working touchpad, but I think you need to disassemble you firmware and find function HWGetPixelPoint
  #605 (permalink)
Old 15th Aug 2010, 12:52 pm
where find all documents and sources of RK2706B?
  #606 (permalink)
Old 15th Aug 2010, 1:10 pm
Deposit Files
Download ALL.
Not only for 2706B, for all rk26 and rk27
  #607 (permalink)
Old 28th Aug 2010, 6:10 am
Hey Baracuda, how is the progress?
  #608 (permalink)
Old 30th Aug 2010, 12:12 pm
I found a OS that fits on a floppy and programmed in assembler: http://www.menuetos.net/,
I thought that since the 2706 Rockchip uses the assembler. MenuetOS changing, we could use it to mpx player
  #609 (permalink)
Old 30th Aug 2010, 1:36 pm
Hi ludovic, the big problem is that assembler language isn't portable. As the rk26xx uses an 8051+dsp combo ucos/freertos may be an alternative.
  #610 (permalink)
Old 2nd Sep 2010, 12:08 pm
in the folder Rockchip games_apps there are games and applications how to integrate them for the RK2706?
and how disassemble my firmware
because i have a file Archos43.img and in the file .img I have 4 folders APPDATA, RESOURCE.SYSTEM ,SYSTEM00 and 3 files RK27BOOT.BIN, RK28IMG.CHK, VERSION.BIN
