Hooray!!! Rockchip SDK!
Like Tree1Likes
  #641 (permalink)
Old 10th Mar 2011, 12:15 pm
WIZARD's Avatar
Originally Posted by DJ_Patron View Post
Ok, problem been solved, I install Visual Studio.
May anyone tell me, where are sysconfig.h, I need it, because LCD of my player have 400x272 resolution.
Check the folder with sources more carefully.
Or, if you don't have it, check the downloads on this page:
Try to play !
  #642 (permalink)
Old 11th Mar 2011, 3:42 am
Post Ohh
Ok, I find it. I change lcd size, but I can't compile it, compiler gave to me error 1381... ЗАЕБАЛО!
  #643 (permalink)
Old 11th Mar 2011, 3:52 am
I can send you SDK for 400x240 screen size resolution, which Knob and I were working on. It's buggy, it's not complete, but it compiles with no problems. I will put it here later in the evening or tomorrow when I have time.
  #644 (permalink)
Old 11th Mar 2011, 3:58 am
Thank you very much! But my player have 480 x 272 screen size...
  #645 (permalink)
Old 11th Mar 2011, 9:47 am
WIZARD's Avatar
Thank you very much! But my player have 400 x 272 screen size...
So, you need to replace 400x240 with 400x272,
and maybe stretch some images to fill the screen.
I hope you succeed
Try to play !
  #646 (permalink)
Old 11th Mar 2011, 9:59 am
Unhappy
I hope you succeed
When I'm try to compile any source of this emu, I have fail.ops:
Compile please... With 480x272, I have a lot of errors, because I'm never have any task in VC++ and over programming before(sorry for bad English, I'm Russian)
  #647 (permalink)
Old 11th Mar 2011, 10:08 am
Smile
I need this emu, because I'm interesting in firmware graphics modding and language packs translating, but I don't want to lost my player)
  #648 (permalink)
Old 18th Mar 2011, 6:47 am
Smile
Please, Flasher! I need it! 480x272 resolution. I'm wait for it)
  #649 (permalink)
Old 31st Mar 2011, 12:12 pm
Smile Fixed the SDK Audio bug!
Had a play around with the SDK for Rk27xx
With a bit of help from the RK2705 datasheet and a very small change to
the Rockcodec the audio is now fine.
In HW_rockcodec.h
//CGR
#define GAIN_INDEPENDENT (0x00<<6)//updated knob
#define GAIN_BYLEFT (0x02<<6)
#define GAIN_BYRIGHT (0x01<<6)
in HW_Rockcodec.c
CodecCommandSet(CGR8, vol_out | GAIN_INDEPENDENT); // updated knob
CodecCommandSet(CGR1, (vol_in << 4) | vol_in); // set DAC input volume GODL and GODR
CodecCommandSet(CGR2, (vol_in + 4) | GAIN_BYLEFT); // set line1 input volume GOBL1 and GOBR1, CGR3 = CGR2
CodecCommandSet(CGR4, (vol_in + 4) | GAIN_BYLEFT); // set line2 input volume GOBL2 and GOBR2 CGR5 = CGR4
I was able to configure all my buttons if I choose the RK2700 chip configuration.
Hope this might help anyone still playing around with RK27xx players and the SDK.:mrgreen:
  #650 (permalink)
Old 31st Mar 2011, 9:25 pm
Default SDK on RK2706b 480x272
I able to compile SDK with ADS but firmware dont start withou errors, but with warnings. Debug start normal but then use func FlashgetChip it go in neverending cycle like this
loop b loop., this funcion in fs_arm_lib.lib. And there is flash.c ?- this function in it....
I hear click on speaker, and white screen. can you help me to solve this in SDK. Reset not work, poweron key not work. Then connect USB i can see system partition... I cant understand there is problem,
player is Ramos T8 clone - Texet T-900 (V40T china model), touch screen 480x272, RK2706b
Sorry for my English, i am frm Russia
