-   -   These chinese onda clones (http://mympx.org/forum/general-discussion/43882-these-chinese-onda-clones.html)
diymania 29th May 2009 12:50 am
I´ve been looking around on the net and on youtube and i notice the clones and the real thing look identical so i think the clones are genuine onda products bought by some noname factory that wash off the onda logo and replaces the onda firmware w that custom crap that look like the real onda firmware but instead has those colored dots for startup screen.
I have a onda clone with 16gb internal memory and 3" touch screen which would equal the VX747, i may download the genuine firmware for this onda model and try it on my clone and see what happens, tho im not sure if theres one firmware version for every memory size but that will show.
What do you think about these thoughts ? The real thing and the clones look totally identical, tho if they were real onda products, the circuit board inside should say onda, unless they use a pcb making service such as carasion.
knob 29th May 2009 2:48 pm
Re: These chinese onda clones
You'll brick it that's what'll happen.
have a look here first ! :-
http://mympxplayer.org/viewtopic.php...ote=viewresult
lolita 29th May 2009 6:22 pm
Open it up and look at the board.
makd511 2nd Jun 2009 5:51 am
original vx747 is a totally different player than 99% of the clones out there, its based on ingenics hardware, clones are rockchip BUT there are some unbranded ingenics BUT very few and none (that i know) in 16GB
dont be fooled by outside appearances or even the look of the UI, the clones are made to look like the original so .. if you do try original vx747 on rockchip copy nothing will happen as firmwares are totally different
