Binaural Sounds...
Old 4th Jul 2009, 5:24 pm
MGebrael's Avatar
Default Binaural Sounds...
This is really cool, you must hear it to believe it.
Find a quiet room, put on your headphones, close your eyes and listen to this amazing digital surround sound to get the full effect (do not use speakers).
It’s amazing!!!
RapidShare
virtual_barbershop.mp3 (4m29s - 6.3 Mb)
Hope that you enjoy!!!
Old 13th Jul 2009, 5:44 pm
MGebrael's Avatar
Did Anyone try???
thk's
Old 2nd Aug 2010, 9:15 am
I bought my new player is for listening to this kind of music. I happened to get a few tracks of Binaural Sound.
Old 2nd Aug 2010, 9:45 am
MGebrael's Avatar
Niceeee.... could you share with us???
did you try this barber shop???
Old 1st Oct 2010, 2:11 am
Just google for them...
Old 17th Oct 2010, 1:51 pm
some time ago I was working on a RKP program which generates binaural sounds at runtime. Unfortunately I encountered some problems with putting generated PCM stream onto DAC buffer. I thought thtat I can use SDK for playing pcm buffer but for some reason it didn't work (probably only my model issue). Nevertheless those sounds are awesome.
I have a complete library of remotehypnosis.com if anyone is interested. I downloaded it years ago while it was free for download. Now it is available for purchase only.
Audio sounds screwed up when a video is played (Solved) NZNillskill Video related 24 26th Jul 2006 3:09 am
