Firmware suggestion
Old 6th Sep 2009, 3:44 am
Default Firmware suggestion
Hi,
Could someone please suggest a newer firmware for a device i bought from ASDA (UK) (Walmaart (US)),
The player is called Curtis MPK7836UKA (4GB)
Ver: 00.00.0004
Date: 11/08/2008
This device runs really slowly. . . also doesnt seem to support ID3 Tags. . . .does a device need a licence to support ID3 tags?
Beanie
Old 6th Sep 2009, 10:10 am
From the firmware id it seems your player is a rockchip rk26xx player.
Can you post a photo of your player to be sure?
Don't mess with the firmware, if it's a rockchip you will kill it for sure.
It should support ID3 tags, without any licence.
Try using ID3v1 tags only and remove any ID3v2 tags. It works ok then on my 2606 rockchip.
Suggestion for good noname mp4 player? ikesmasher General Discussion 2 17th Apr 2009 3:20 am
SUGGESTION | always include board & player info w/ firmw doon General Discussion 1 7th Jul 2006 6:24 pm
Suggestion: Battery Icon fizzle05 Mods and Themes 22 13th Jun 2006 11:51 am
MP4 player suggestion and question Blackwar2000 General Discussion 4 26th Mar 2006 8:25 pm
