Yes this is another one of what player is this
Old 20th Oct 2009, 5:25 am
Default Yes this is another one of what player is this
This is the new player i bought it claims to play 8-32bit games . All it had was some .bin games and i tried to play genesis games on it but it said unsupported . These are it's other features . Kindly help me figure out a way to play genesis and 32 bit games on this device . Also i'd like to knw where can i get 32 bit .bin games??
Can i install ne emulators on this device ???
1) 3.0 inch TFT display
2) Built-in the loudspeaker
3) Support MLC Flash(Max: 2GB)
4) Support MINI SD card(Max: 2GB)
5) Game function. Support 8-32bit NES format games to download
6) Digital vidicon/camera function, Digital camera with 1.3M pixel, Support EXIF2.1
7) Audio play function, support MP3/WMA/AMR/ACC & WAV etc, Support the LRC lyrics to show synchronously
8) Movie play function, support network movie: ASF, 3GP, MPEG-4 format.
9) Support FM radio function
10) Support Video output, AV OUT (TV-NTSC/TV-PAL)
11) Support AV-in (optional)
12) Built-in microphone recording
13) Photo browsing function, support EXIF2.1
14) E-book function,
15) Ten thousand calendars, time display, calculator.
16) Built-in lithium battery, can continue to play video for about 3.5 Hours, MP3 audio for about 6 hours, (Screen saver mode, inside sound)
17) Dictionary. Words and phrases to support the MP3 live pronunciation
thanks
Old 20th Oct 2009, 6:21 am
WIZARD's Avatar
Wink
I've played in a lot of Sega Genesis games using Kega Fusion.
All the Sega ROMs are in .bin or in .smd format.
You can download the ROMs from Sega Genesis Roms at ROMNation.NET
or from Sega Genesis Roms - A - ROM World
If your favourite game has .smd and you can't find the .bin one,
just use this small program to convert .smd to .bin :
ROM Converter - Genesis Utility in General Category - Zophar's Domain
Try to play !
Old 20th Oct 2009, 8:00 am
thanks for the info dude but what u r telling me abt is a PC util not for my MP4 player
Old 22nd Oct 2009, 5:04 am
WIZARD's Avatar
Wink =)
If your player supports only .BIN not .SMD :
You can download a lot of .BIN games from those sites I've posted above.
And in case if you love the game which is not so famous,
and it's in .SMD format and you can't find the .BIN version,
just use the utility on your PC to convert.
Try to play !
