Stuck on welcome screen?
Old 29th Mar 2010, 2:40 pm
DHK DHK is offline
Default Stuck on welcome screen?
Just got my little idiot box today and i can't get past the welcome screen lol. I can reset it but it just keeps coming up the same, any ideas? It would be nice if my pc could pick it up so i can try and fix it..!!
Old 1st Apr 2010, 1:47 pm
Well that isnt enough information.
on OTHER devices that dont leave the welcome screen, i would check these things:
Memory, any external memory , remove, test, re-format replace. any internal memory test (hard to do that one)
Charge it, then DONT have the charge connected when booting
Dont have USB connected when booting
you check memory because if it is MID boot the driver things start to init and access the memory, if the memory has even slight corruption areas it might take LONG to init, or never get past it.
the reason to not have charge attached, is some devices boot different with charge attached
the reason to not have USB (or other external connections) it might be jumping into a different mode.
the reason to start with full charge , is so the voltage is all ok and you can HAVE the other stuff disconnected on boot.
good luck
Help me! MP4 gets stuck on welcome screen YASLICOCUK38 Support and How To 20 18th Jan 2010 6:53 am
mp5 stuck in blue screen gogi Support and How To 3 2nd Aug 2009 9:22 pm
help my mp5 stuck in blue screen gogi Dead Players 0 7th May 2009 9:38 am
My Glacier is stuck on the hourglass screen! moosealert General Discussion - Uxcell.com 27 29th Mar 2007 9:03 am
My i-platinum is stuck on the hourglass screen! filpo General Discussion - Uxcell.com 6 10th Mar 2007 9:52 pm
