Snow Angel BX-10 review - clock,radio,speaker and mp3 with remote
Old 22nd Jul 2010, 2:13 am
KPAH's Avatar
OK, this jack
http://www.cui.com/pdffiles/SJ-3568N.pdf
should make it possible to create a poormans lineout, by soldering speaker wires to the audio jack post and wiring the speaker gnd cables throuth the 4-5-6 terminals of the jack.
Wonder if gnd's of the speakers in this device are separated or could be joined.
Old 24th Nov 2010, 9:13 am
I would like more contrast.
How it could be fixed by a little soldering?...Thanks!...
Old 5th Dec 2010, 9:35 am
KPAH's Avatar
Dunno, I have enough contrast. Too much lcd backlight though.
Anyone, I gave up on the device. It fitted perfectly on my kitchen table. Only listen to FM, don't even stick in mp3 no more
Worth the money 100%
Old 19th Jun 2012, 8:32 am
That Snow Angel device may be based in Actions Semiconductor ATS250X series chipset, but a low series because it includes apart the FM module, and in newer series (ATS2503) FM module is included inside the chipset. I have an ATS2503 based model called New Angel, and I want to find the firmware of my device but with any luck until now. You can connect the device to a PC thru using an USB male-male cable, then , you must put the sitch in off mode, and then connect to PC, then the device is recognized as microsd card reader unit. Try to use S1fwx or S1res to extract firmware, in my device I dindīt have any success.
Old 19th Jun 2012, 11:37 pm
KPAH's Avatar
I think it is impossible by now.
The only thing I did so far is solder another on-off switch to the top of the device, since the back one is not exactly convenient.
  #16 (permalink)
Old 13th Jul 2012, 1:32 am
KPAH's Avatar
  #17 (permalink)
Old 13th Jul 2012, 7:04 pm
Looks like it's Actions-based
Player only recognizes 47, clock not set, radio won't play bdjohns Support and How To 2 29th Mar 2009 6:46 pm
clock settin 24 vs 12 Camaro Support and How To 3 24th Feb 2007 2:53 pm
Review: New Teclast T29 4GB Player Review tadad1 General Discussion 3 1st Nov 2006 2:55 am
[Solved] Listen FM Radio via Loud Speaker vsx70 Support and How To 3 31st Oct 2006 10:51 pm
Clock function Iridium Support and How To 7 30th Jun 2006 1:04 am
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
