Problem Playing Movies From Micro SD Card (Restarting)
Old 7th Jul 2010, 11:14 pm
Question Problem Playing Movies From Micro SD Card (Restarting)
Hi,
I have a 4.3" Touchscreen MP5 player which I have to say works really well, except if I play a movie from the SD card?? It will play approx 30 seconds to one minute before automatically skipping to the next movie on the card or if it is the sole movie on the card it will just restart the movie again. I have tried the following....
Please note that everything works as normal from the internal memory
Same Movie On Internal Memory as on SD Card
different movie on SD Card
2 different 4GB Micro SD Cards
A 8GB Micro SD Card
placing the movie on the root of the card & in folders on the card
3 different movie encoders & formats
Any Help would be greatly appreciated!!
Old 8th Jul 2010, 3:54 am
Format the Card using different cluster size. Perhaphs the Card has unusal FAT32 format. You have a lot of options to check, format format and check.
Old 8th Jul 2010, 11:18 am
Question
Hi
Many Thanks For Your Reply....
I have tried what you said & tried formatting the card using the following settings
FAT (All Allocation Unit Sizes)
FAT32 (All Allocation Unit Sizes)
NTFS (Card Not Recognized)
exFAT (Card Not Recognized)
Unfortunately there is no difference.....The movie will play for maybe 10 seconds then restart, maybe 3 minutes.....maybe 5 minutes...but will just restart if it is the only movie on the card or move on to the next movie if there are more than one on the card..
Any other suggestions?
Cheers
Old 8th Jul 2010, 11:32 am
you bought cheap player with buggy firmware, that's a problem. I don't think you can overcome those problems, as I assume there is no further support for your player regarding firmware updates. You may experiment with RK27 SDK. I don't know if your player is RK27 or RK28 but some people claimed the firmware has the same structure in both types. Another clue for supporting that hypothesis is that they both have ARM processor (RK27 has ARM7, and RK28 has ARM9?) and therefore ARM7 instructions should work on ARM9.
As you can see it's very complicated, so I can't tell you anything optimistic.
You may also give a shot with different firmwares. Try looking for player with similar keyboard, screen and such (only if you can restore your original firmware).
Old 8th Jul 2010, 12:34 pm
Hi,
Thanks for the quick reply, I have the RK27 SDK & the hardware ID is 100111 & the Major Version ID is 2.4, I have tried to see the hidden partition by placing the file on the root of the flash memory but nothing ever appears...so I guess that there is nothing I can do???
Old 8th Jul 2010, 1:29 pm
try using different name for file. default is rkusb.tag but it may be different. Look up this forum, there was a list of alternatives for this file somewhere.
iVO-Sound m1050 can't read 2nd video file on micro SD card Shank Support and How To 0 26th Oct 2008 1:49 pm
playing movies on my onki mv-70 player cajunboy70785 Video related 1 5th Sep 2008 1:39 am
4gb Nano Clone with a restarting problem Uncle_Chop_Chop Dead Players 18 7th Jan 2007 1:02 am
Screen broken, flip movies and playing MP4 question Bugmenot-User Support and How To 0 2nd Dec 2006 6:05 pm
"Format Error" while playing AMV Movies jasstone Support and How To 5 2nd Aug 2006 10:18 pm
