-   -   Ali's M7103 cpu Pm splitter (http://mympx.org/forum/general-discussion/45973-alis-m7103-cpu-pm-splitter.html)
aslamahmed 26th Jun 2011 2:27 pm
I have a hitachi dmp860 mp3 player which also contains an Ali's CPU, I used the isp tool 0.96 to backup pm.bin from a working dmp860 but i could not program it, it says "Invalid Filename" and if i use mptool, it need the firmware which has .cab extension unfortunately i cannot find the splitter or converter.If someone has the firmware or spliter or any other way of flashing the player please inform me.
aslamahmed 27th Jun 2011 3:29 pm
no one has any information or solution.I bet lolita has some information, it would be very helpful if he can share.
aslamahmed 1st Jul 2011 2:40 pm
anyone please post something
Nedemai 24th Sep 2011 5:17 am
I have a coby mp3 player that uses an ALi chipset. From the research I've done on these chipsets the firmware tools will allow you to take a binary dump of the entire firmware. The tools that program the firmware expect a different format however. The ISP tool will allow you to program the firmware but it seems to want a small section of the binary at a time rather than the entire dump. I cant exactly say how this works because I am unsure.
These is another tool usually included called Factory4.exe. This tool will program a firmware onto ALi devices however it expects the firmware to be a cab archive with each section of the firmware clearly defined in it. This link has some very useful information about the process.
ALi M5661 Chipset MP3 Player Recovery and Hacking - Loading New Firmware
Another thing to note is there seems to be different versions of the ALi chip. There is a M5661 and a M7108 chip it appears, as well as other variants in the respective series. Both of these chips require slightly different ISPtools to be able to program them as well.
I hope this information helps you.
