Automatic PAUSE - possible?
Old 16th Jul 2011, 8:16 am
Default Automatic PAUSE - possible?
Hi to all,
I bought MP5 4.3" player (no brand, no name), but it's exactly the same as in the video below:
The player is nice at all, but I wonder if it's possible to modify a function with firmware, so:
Is it possible to make the firmware so that the player goes automatically on PAUSE at the end of a song? Then the PLAY after choosing any other song to be manually started?
Now it's a big disadvantage to me that when I press PAUSE and then scroll to choose any other song, the player automatically starts to PLAY the wrong desired songs during the whole scrolling.
Also, which firmware is exactly for this model?
Big thanks in advance!!!
Old 30th Jul 2011, 8:25 pm
Hi producer,
I think the first thing to do is post the firmware version of your player. You can do this by going into the "Setup" section of the menu and look for something that says "firmware info" or "firmware version". That will give us a better idea as to what chipset your player has based on the firmware version.
With regards to your question, to be honest with you, being able to modify a FUNCTION within a player is very difficult and I would say almost impossible for any existing tools available that will enable you to modify the functions of a player. Some tools will enable you to modify the look and theme of the player, but to be able to change the playing of music and how it functions will be near impossible. Unfortunately there's just not tools available out there for that kind of thing. Also a lot of these players are from China and they will not release any tools due to their Intelliect property.
I've tried for many years to try to get tools released from manufacturers, but the chipset manufacturers won't release them.
Hope that helps.
Automatic STMP3500, Help Needed rascard2007 Dead Players 0 7th Sep 2009 9:21 am
automatic changing of language :/// Rychloun Support and How To 0 13th Mar 2007 6:53 am
Automatic fw extracting Bugmenot-User Support and How To 0 10th Nov 2006 6:36 pm
pause function (music) resets to 1st file, 1st folder joshatx General Discussion 1 13th Sep 2006 7:00 pm
