Go Back MyMPx.org > MyMPx.org Forum > Knowledge Base and FAQ
How to: Set sleep and power off settings
Old 31st Jan 2006, 12:39 am
Default How to: Set sleep and power off settings
What you have to do is:
1. You must set the clock/time on the player firstly. This is really important otherwise it won't work.
2. After that, go into your "LCD Set" menu and change the "black" (it might be called "darkle" or similar on some players) to the number ZERO (lowest number).
3. Now go into your "Power Off" and set the "Off Time" and "Sleep Time" to number ZERO as well.
4. The most important thing on most of these players is that you have to turn off the player by pressing down on the "play/pause" button. DON'T use the [On/Off] switch as this will reset your clock settings back to default!
Your player now won't go into a sleep mode or turn off after a certain amount of time. You'll have to remember to turn your player off if you're not using it that's all otherwise you'll drain the batteries .
Hope that helps.
sleep time ZooL Support and How To 2 2nd Aug 2010 8:15 am
How to get MP4 player out of sleep mode? imjustme31 General Discussion 2 3rd Jan 2010 10:41 am
Firmware, Games, and Sleep primetime34 Support and How To 1 2nd Jan 2009 10:56 am
What exactly does the Sleep Time setting do? sanelson Support and How To 5 14th Mar 2007 1:27 pm
[solved] Sleep Mode castagno Support and How To 3 9th Jun 2006 10:42 am
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
