Go Back MyMPx.org > MyMPx.org Forum > Knowledge Base and FAQ
How to: Convert to .AMV using the MP3 Player Utilities 3.68
Old 14th Mar 2006, 12:55 am
Default How to: Convert to .AMV using the MP3 Player Utilities 3.68
Here are the instructions on how to convert to an .AMV video file using the AMV Convert Tool 3.68 - MP3 Player Utilities 3.68 which can be downloaded here.
1. Open "AMV Convert Tool" from the [Start] --> [Programs] --> [MP3 Player Utilities 3.68] menu.
2. Click on the [Add File] icon on the top right of the AMV Video Convert Tool screen.
3. Select the file you want to convert then press the [<span style="font-weight:bold">Open</span>] button.
4. You will now see your file below in the queue.
5. Select the file you want to encode in the queue list below. Then press the [Settings] button on the right hand side to change your encoding settings. If you don't select the file, the [Settings] button is greyed out and you can't click on it.
6. For "screen width and height", change it to "128x96" if you have a 1.5" screen player, or "96x64" if you have a 1.2" screen player.
Make sure "Frames per second" and "image quality" is set to "high".
"NOTE: If you have problems with 'Format Error" messages during playback on your player, change the "image quality" to "medium" instead.
Tick "Try another codec" if you have errors trying to encode a video to .AMV, this might fix it.
Click on [OK] button.
7. Click on the "AMV Path" button on the top right to select where you want the new .AMV file to be outputted to.
8. Click on the "Begin" button to start encoding.
9. It will now convert your video and show you the progress down the bottom.
10. If successful, you will the following prompt. If the convert fails, try putting the tick in "Try another codec" option box in your [Settings].
Tags
convert to .amv
New MP3 Player Utilities 4.18 masss General Discussion 0 10th Mar 2008 7:27 am
I need mp3 player utilities v4.05 blue Dead Players 2 30th Jul 2007 11:17 pm
MP3 Player Utilities 3.11, 3.8 or 4.11 Nonie Support and How To 2 9th Apr 2007 12:03 am
MP3 Player Utilities 4.05 veggen Video related 4 21st Sep 2006 3:28 am
How to Use MP3 Player Utilities 3.68 EBJohnson Support and How To 12 14th Apr 2006 12:41 pm
