Go Back MyMPx.org > MyMPx.org Forum > Knowledge Base and FAQ
How to: Solve problems installing AMV/MTV Converting Tool
Old 29th Mar 2006, 1:04 am
Default How to: Solve problems installing AMV/MTV Converting Tool
If you have problems installing the AMV Convert Tool or the MTV Convert Tool, you can try following these steps to see if this helps solve your problem.
1.
Delete all your TEMP files. Go to C:\Documents and Settings\<<your_logon_username>>\Local Settings\Temp and remove all the files in there.
Try running setup.exe again and see if it works. If not:
2.
Try redownloading it from our website again, save it to a DIFFERENT location, maybe just the root of C:\drive and extract it into a folder in the root of C:\drive. Try running the setup.exe from there and see what happens......
If that doesn't work:
3.
With Windows XP and Windows 2000, create another user account. Give that new user account full admin rights. Try installing it while logged in with the newly created admin account and see what happens? It might be a profiles problem.
Try those, if you have any other suggestions, let us know.
Problems installing/uninstalling Mp3 Utilities 4.03 omega1 Support and How To 6 26th Dec 2006 4:12 pm
iPod nano lool-alike installing problems honeybfly_jr Support and How To 3 17th Sep 2006 2:33 am
Problems Installing AMV 3.68 onto computer Simonski Support and How To 6 22nd Jun 2006 1:34 am
problems with converting in .amw Romik Video related 3 9th Jun 2006 5:47 am
Problems converting files to amv DaSilva Video related 1 3rd May 2006 2:29 am
