Go Back MyMPx.org > MyMPx.org Forum > Knowledge Base and FAQ
How to: Modify your firmware using s1res tool
Old 9th May 2006, 1:33 am
Default How to: Modify your firmware using s1res tool
[html:b431098a60]
<table width="100%" border="0" cellpadding="0" cellspacing="0">
<tr>
<td valign="top" class="postbody">
<hr />
You can modify your firmware using the s1res tool.
<div style='float: right; margin-top: 0px; margin-right: 5px; border: 1px dotted #d5d6d7; clear: both; padding: 5px;'>
<script language='JavaScript' type='text/javascript' src='http://www.mympxplayer.org/phpAdsNew/adx.js'></script>
<script language='JavaScript' type='text/javascript'>
if (!document.phpAds_used) document.phpAds_used = ',';
phpAds_random = new String (Math.random()); phpAds_random = phpAds_random.substring(2,11);
document.write ("<" + "script language='JavaScript' type='text/javascript' src='");
document.write ("http://www.mympxplayer.org/phpAdsNew/adjs.php?n=" + phpAds_random);
document.write ("&amp;what=zone:13");
document.write ("&amp;exclude=" + document.phpAds_used);
if (document.referrer)
document.write ("&amp;referer=" + escape(document.referrer));
document.write ("'><" + "/script>");
</script><noscript>Click the image to open in full size.</noscript>
</div>
<span style="text-decoration:underline">Requirements beforehand:</span>
* Make sure you have extracted the firmware using the <span style="font-weight:bold">s1fwx</span> tool as you will need the .bin file so you can modify it with the s1res tool. Read the Knowledge Base here - How to: extract firmware of your player using the S1fwx tool.
* Make sure you have downloaded the <span style="font-weight:bold">s1res</span> tool already. Download it from here. You will need it to open the .bin file and modify your firmware with it.
<span style="font-weight:bold"><span style="text-decoration:underline">STEPS ON HOW TO MODIFY YOUR FIRMWARE:</span></span>
1. Run the <span style="font-weight:bold">s1res.exe</span>.
2. Click on "File" then "<span style="font-weight:bold">Open</span>" from the top menu.
3. Navigate to your .bin firmware file, select the file then click on the [<span style="font-weight:bold">Open</span>] button.
3. You will now see this screen (or similar) below:
4. A description of what each section is used for is explained below. It might vary alittle depending on how the firmware has been constructioned but it should be very similar.
5. To modify the END sequence, click on [<span style="font-weight:bold">END.RES</span>] section on the left hand side bar. Click on the [<span style="font-weight:bold">+</span>] sign next to it to expand it. Then expand "icon". You will now see a list of files that are used to make up the ending sequence of your player. Some players have more, some have less and some only has ONE end sequence image.
5a. If you click on "001", you can see a "Preview" of the image. Your files might be named differently, but follow the same structure - the first, top photo is the beginning of the end sequence.
6. To replace the images with your own image, you will need to save all your images as a .<span style="font-weight:bold">BMP</span> file with Depth: <span style="font-weight:bold">24 Bit</span>.
6a. Click on [<span style="font-weight:bold">Import</span>] button.
7. Browse to the image you want to replace it with and press the [<span style="font-weight:bold">Open</span>] button.
8. You will now see your new image in the "Preview" box and also in the "Edit" box below it.
9. Carry on and replace the other images with your own images.
10. You can then modify the Start sequences under the [LOGO.RES] section and follow the same steps as above.
11. To modify the images used within your player, you can do this by importing images into the [UI30.RES] -> "<span style="font-weight:bold">icon</span>" section.
12. To modify the <span style="font-weight:bold">TEXT</span> used in your player, select [UI30.RES] -> "<span style="font-weight:bold">mstring</span>".
13.
(1) Select the text string you want to change
(2) Select the text string you want to change on the right panel
(3) In the "Edit" box on the bottom, change the text to what you want it to be.
NOTE: You must use the <span style="text-decoration:underline">same or less than</span> the text characters that are already there. For example, if you decide to change the text "Del. all?" (8 characters), you can change it to "Del All" (7 characters), but you <span style="text-decoration:underline">can't</span> change it to say "Delete All" (10 characters).
14. Once you have finished, click on "File" on the top menu then choose "<span style="font-weight:bold">Save</span>".
15. To upload the firmware onto your player, follow this Knowledge Base - How to: Update the firmware for your MP3/MP4 player.</div></td>
</tr>
</table>
[/html:b431098a60]
ATJ213X Firmware Modify Tool Finally Here.. waldopulanco Mods and Themes 7 2nd Oct 2012 4:46 am
Extract/Modify Firmware v 9.1.52 Using s1res! theillusionist Mods and Themes 10 23rd Mar 2009 3:37 am
Modify theme with S1res at my rockchip mp4 player? GunChEsTeR Mods and Themes 3 16th Dec 2007 1:57 am
[solved] Where to download s1res tool? armendvisoka Support and How To 3 15th Jul 2007 3:08 am
Why can't my s1res tool open my extracted BIN file? .::Lain::. Support and How To 4 21st Jan 2007 4:35 am
