Suggestion: Battery Icon
Old 31st May 2006, 2:35 pm
Default Re: Suggestion: Battery Icon
sounds good, don't forget to post results
Old 31st May 2006, 4:42 pm
doesn't seem to be able to show all 9 levels.. just testet it.. for about 95% of the time it was showing level 1 ... then level 2.. i got a "low battery" message then the player shut down.. after restart i had level 3 for about 1-2 minutes then the same as before.. restart and now level 9 is shown.. seems the levels in between are skipped.. and everything besides level 1 only appears during the last few minutes before the battery is empty...
Old 31st May 2006, 5:49 pm
I would say the 9 images are more for recharge animation than accurate battery level indication.
Old 1st Jun 2006, 2:04 am
recharge animation? there are totally different images for that
Ultimate guide is no more
Old 1st Jun 2006, 2:11 am
Egotrippin that sounds really weird, if thats true with everybody, then that is the manufacturers fault surely, because we are only altering the firmware images, and they are in the right order. if thats the case with you, originally your player must have never shown battery empty. Im going to test mine now, I need to see how long the battery lasts anyway, will post results. Perhaps mine is the same, it has had "full battery" for a while....
  #16 (permalink)
Old 1st Jun 2006, 2:36 am
I have one set of nine battery images and they show for both usage and recharge.
  #17 (permalink)
Old 1st Jun 2006, 3:24 am
oh....mines a bit different, i have ones with a blue background for the status and ones with a green background for recharge which i didnt bother to change as it doesnt matter to me.
Well....results are as follows.....after playing a video for an hour and a half on max volume the battery has gone down, and in the right order! problem is, it went down to 75% :x that has completely ruined this thread lol but at least people can download the battery bit to get the coloured icons
this battery lasts ages
  #18 (permalink)
Old 1st Jun 2006, 4:10 am
the fact that it has shown the empty battery with level 1 in my case shouldn't be a problem since it has shown the full battery with level 9 .. so i can put the images in backwards and it will be fine..
but as i said.. its a bit strange since before i modded the firmware level 1 had the full battery image
  #19 (permalink)
Old 1st Jun 2006, 5:22 am
:roll: looks like the firmwares as good as the instructions :lol:
  #20 (permalink)
Old 12th Jun 2006, 3:49 pm
Boto
Guest
Posts: n/a
My firmware have just 6 icons for the battery, from BATTLV1 to BATTLV6... =(
How can I add more icons? So I could use your modification with 9 icons.. =)
Firmware suggestion PerpetualOmega General Discussion 1 6th Sep 2009 10:10 am
Suggestion for good noname mp4 player? ikesmasher General Discussion 2 17th Apr 2009 3:20 am
Add a Drive Icon to your player AJ Support and How To 3 17th Mar 2007 8:14 pm
[solved] busy icon after upgrading the mp4 mashranga Dead Players 3 6th Oct 2006 5:23 pm
MP4 player suggestion and question Blackwar2000 General Discussion 4 26th Mar 2006 8:25 pm
