{SOLVED} Issue with changing theme stuff...
Old 11th Jul 2006, 11:10 pm
Default {SOLVED} Issue with changing theme stuff...
Hello all. I'm a new mp4 nano clone owner and first time poster. I had a bit of an issue after changing my theme from the ugly flowers to a ipod menu.
I changed over everything fine: backup my bin file, edited the current bin file , but found out i mixed up a couple images after I turned my player back on. So i thought, no prob, ill just fix em and upgrade my firmware. After fixing it, i tried to upgrade my firmware only to get an error message in MP3 Player Utilities 3.68 after clicking Begin Upgrade that says 'Invalid upgrade firmware file!'
I tried using my edited bin file as well as my backup and i get the same result. Any suggestions?
Any help is greatly appreciated
PS- This forum is fantastic BTW
Old 12th Jul 2006, 12:08 am
scape211, Did you run repair.bat in the s1fwx folder when you extracted your firmware?
Also uninstall 3.68nand install 4.0 and try to restore your unthemed dump.bin.
Old 12th Jul 2006, 5:53 am
Default Re: Issue with changing theme stuff...
i certainly did repair it. i followed the instructions listed on this website. I imagine it has something to do with the program. I kept having a problem where it would not recognize my mp4 player even though it was plugged in and windows showed it perfectly. After it finally did recognize it, i got the error i explained above.
So now my question is where is version 4.0 for the mp4 utilities? i didnt find it in the downloads sections before...(might be because im still a bit noobish with the navigation of this site though so forgive me)
Old 12th Jul 2006, 5:39 pm
i think my problem is solved. After you said to make sure I repaired the backup tadad1, I re-repaired it to make sure it worked and it didnt not. I dont really understand why it worked the first time I repaired and not the second, but i extracted and repaired all over again and i was able to upgrade fine in MP4 Player Utilities 4.0. I unfortunately dont have my original firmwire with the standard menu, but I should be fine with this edited one.
Thanks for the help
Old 14th Jul 2006, 6:40 am
scape211
That does sound strange.
Are you able to 'reload' our modified firmware file more than once?
Old 14th Jul 2006, 10:35 am
well, here is the thing. I read on another post that you cant repair a file twice and I didnt know that when i tried to repair a second time. So technically, the file could've been repaired already. However, since it didnt work, i just extracted what I had, which had the ipod boot/end sequence and ipod menu, then I repaired that and reuploaded and it worked.
In short, yes admin I can reload it more than once.
Old 14th Jul 2006, 1:53 pm
scape211
Yes, you can't repaird it more than once, you just get an error.
Good that you solved it in the end and that it's letting you flash your player more than once. I was suspicious that it might be a problem with the USB cable if you are having USB detection problems in Windows. But guess not.
If your question is solved, can you put [solved] in the subject of your original post please?
Changing the Theme Nightfrost Mods and Themes 2 25th Nov 2009 8:14 am
Need help changing theme for ME2 mp3/mp4 player gleno007 Mods and Themes 0 20th Jan 2009 8:49 pm
Changing my theme for nano clone Mother Superior Mods and Themes 2 14th Dec 2007 11:27 pm
changing the theme OdangoAtama Mods and Themes 1 13th Nov 2007 10:37 am
A lot lot.. of questions, changing the theme.. Yusko Mods and Themes 4 30th Sep 2006 6:55 am
