Problem Change Boot and Shutdown Sequence
Old 2nd Sep 2006, 2:07 pm
Default Problem Change Boot and Shutdown Sequence
Hello,
my name is Vincenzo.
This is the first time that i write on this forum
Compliments for all.
Sorry for my english but i don't speak very well.
My problem is this.
I would like change boot and shutdown sequence of my Mpx.
I backup my firmware.
I download this file My1Pod and i see that are many file, include Boot and End sequence.
When i see the end sequence i see 13 images, but my original firmware i see that have 7 images for end sequence.
Is it possible insert new images?
Thanks and sorry for my english.
Vincenzo
Old 2nd Sep 2006, 2:41 pm
vincenzo79
Currently there isn't a program available that will let you insert more images into your firmware file.
If you only have 7 images, then unfortunately for the time being, you can not insert more.
What I suggest is to just insert every second image of the MyiPod theme into your firmware. Example: insert images 1, 3, 5, 7, 9, 11, 13. That will be 7 images.
Hope that helps.
Old 2nd Sep 2006, 2:51 pm
Default Re: Problem Change Boot and Shutdown Sequence
Yes good idea.
Last question.
My firmware is:
MP3 Player
SC85051D
2006/04/05
ACT_v3.5.35
I download this theme My1Pod.
Do you think that are problem with version of firmware?
Thanks Vincenzo
Old 2nd Sep 2006, 3:20 pm
vincenzo79
If you just use the images but import them into YOUR firmware, you shoud be fine.
The problem arises when you try to use OTHER people's firmware on your player. If you backup your firmware (best to make TWO backups) then change only YOUR firmware, then reload it back then it should be fine.
How do you change the boot screen? r2ppar Mods and Themes 1 24th Apr 2007 3:59 am
How to change boot screen? skhoo Mods and Themes 10 30th Oct 2006 4:08 pm
AMV files with low audio bps sequence Csaba Video related 0 21st Jul 2006 2:56 pm
Cool bootup/shutdown sequence Rocker81 Mods and Themes 1 5th Jul 2006 5:26 pm
change shutdown image Support and How To 5 4th Jul 2006 1:22 pm
