-   -   Problems with theme (http://mympx.org/forum/mods-themes/34725-problems-theme.html)
vvizard 26th Oct 2006 10:57 am
Problems with theme
because none of themes from this site doesnt work with my player, I tried to create my own theme.
What should I do to eliminate blue(black, dark green) rectangle from background screen. example when radio doesn't find any station theres blue rectangle on my background screen, but when finds station player generates in this place bitamp.
lattesurf 26th Oct 2006 8:36 pm
Re: Problems with theme
vvizard , when you use the S1res tool to edit/import your images files, whatever that is in there can be changed. But whatever that is not there, cannot be changed. Some parts of the images used in the player are fixed to the firmware operating system and you need to design around them.
