modifying firmware
Old 16th Nov 2006, 1:10 pm
Default modifying firmware
i tried to open the dump.bin with s1res.exe
it shows this message
An attempt was made to load a program with an incorrect format.
get info from device...
ic version = 0x7676
storage info = 0x0602, 0x0001, 0x0000, 0x0000
device = 'LISONG MP3 Player'
bootflash type = 'F285'
brom version = 3.0.80
firmware version = 9.0.48
read boot record...
detect firmware size...
error: The system cannot read from the specified device.
read flash...
write to file 'dump.bin'...
filename = 'dump.bin'
filetype = afi
md5 = 3BB70F9B2E50B1180BD71D755B1B7C22
file id = 'AFI '
vendor id = 0x6977
product id = 0x6552
version = 9.0.48
date = 00/00/0000
| BRECF285.BIN | | 16kb | | F285 | | B | | D2D84CD9 |
| SYSINFO.BIN | | 192bytes | | | | | | 1051E35C |
filetype = unknown
MP3 PLAYER
LSD-9101-20
2006-10-21
9.0.48
2005-01-09
i uploaded it http://rapidshare.com/files/3640703/s1fwx.zip.html
i want to put the myPOD theme into it, but i cant open the dump.bin file :<
Old 16th Nov 2006, 1:54 pm
xeongx,
Until s1fwx is upgraded you will not be able to mod your firmware. At the moment it is not possible to make a usable backup copy of the 9.0.XX firmware so unless you have the players original Full Version firmware you will not be able to modify it.
Old 16th Nov 2006, 2:14 pm
so everyone else is having the same problem with this?
Old 16th Nov 2006, 2:40 pm
xeongx, Well everyone with the 9.0.XX series firmware anyway.
Old 16th Nov 2006, 7:49 pm
is anyone making the 9.0.XX tool yet?
is there official site for it? or its here in this forum?
when it would be out
cuz i really dont like the current theme :<
Old 16th Nov 2006, 8:26 pm
xeongx, the s1fwx tool is made by "wiRe" his site is www.s1mp3.de . He is aware of the problem but as yet no news on an update.
Old 17th Nov 2006, 2:14 pm
do you think full firmware version is availbe for me?
how about if i put another firmware in it??
Old 17th Nov 2006, 3:08 pm
xeongx, There is bound to be a full version of your firmware but finding it is the problem. I strongly suggest that you do not try to change your firmware. Your player is using a newer chipset which is why it has the 9.0.XX series firmware and not 3.5.XX series. If you kill your player which is more than likely you will not be able to recover it unless you find the full version for your player.
Old 17th Nov 2006, 6:05 pm
so full version is the one we can get from the tool that its not realed yet for 9.XX??
could the seller i bought it from have the firmware?
Old 17th Nov 2006, 6:38 pm
xeongx, The problem with the s1fwx tool at the moment is it misses a couple of files in the extraction process and because they are not there it can not repair the firmware.
An extracted or dumped firmware is not the same as a full version firmware. A full version firmware contains certain extra files that are used to read the players hardware and prepare the player for firmware installation. These extra files are not actually copied to the player during the firmware installation, this means that there is no way to extract a full version firmware because not all the files needed are present on the player.
Your possible options for a full version firmware are the mini CD that came with your player sometimes has a copy but this is rare. The supplier may have a copy or may be able to get a copy but sometimes the manufacturers are a bit reluctant to release their full versions in case other manufacturers start using it.
extracting and modifying a firmware Valkyr Support and How To 0 10th May 2009 8:58 am
Modifying .fw firmware file? mp4lover Support and How To 2 19th Dec 2008 12:22 am
Will pay for help modifying firmware rlaboris Firmware 0 22nd Jul 2008 2:26 pm
Modifying player with 9.1.50 FW? I_SAY Mods and Themes 14 6th Jul 2007 6:39 am
modifying my original FW raz Support and How To 2 4th Sep 2006 6:11 pm
