Can't change V9.0.48 firmware using s1res
Old 17th Dec 2006, 12:50 am
hi, mine just bought mp4 player a 2gb ipod nano alike model, yesterday,
same with you the firmware version is 9.0.48
so it mean that i currently cant edit the firmware nor changing its theme?
The current theme from the manufacture is suck, i don't like it at all
Old 17th Dec 2006, 1:30 am
skoolboy, If your player came with a copy of the firmware on the Mini CD then you may be able to edit that but you can not extract the firmware from your player to edit it.
Old 9th Jan 2007, 1:41 am
I have a nano clone 2gb. firmware is 9.0.50
I cant seem to backup my firmware and also no way to upgrade it. If i can somehow get a copy extracted, cant i just edit that and use upgrade tool?
But the issue is that even the upgrade function doesnt seem to work.
Old 9th Jan 2007, 1:59 am
junooni, There are no tools yet to backup\extract 9.0.48 or 9.0.50 firmware.
Old 14th Jan 2007, 6:56 pm
Default Re: Can't change V9.0.48 firmware using s1res
YOU CAN EDIT THE THEME ON 9.0.48. Just read my thread, it explains how.
Extract/Modify Firmware v 9.1.52 Using s1res! theillusionist Mods and Themes 10 23rd Mar 2009 3:37 am
Extract 9.X.XX firmware using s1res luiz127 General Discussion 1 9th Oct 2008 1:46 am
cannot change the "mstring" on s1res uninet Mods and Themes 0 22nd Feb 2008 1:17 am
S1res doesnt work with 9.0.50.00 firmware lien198 Support and How To 2 3rd Jan 2007 11:02 pm
How to: Modify your firmware using s1res tool admin Knowledge Base and FAQ 0 9th May 2006 1:33 am
