"Voip locked" after succesful modding
Old 27th Nov 2006, 9:15 pm
Default "Voip locked" after succesful modding
Hi,
I'm new on this forum.I recently bought an mp4 player..With the guide in this forum i succesfully modded my player with a new theme,but afterwards i always see during power on/off this message..."VOIP is locked! Need update it!....whats wrong with this? but functionally i have no problem at all wiyh my player..Hope some can enlighten me with this problem..
Old 27th Nov 2006, 9:41 pm
Default Re: "Voip locked" after succesful modding
Davi , was the firmware dump that you used to flash into your player, your original firmware or from someone's firmware dump in the forum?
There was a thread on this voip issue sometime back, the thread is Here. You might want to have a read on this first.
Old 27th Nov 2006, 10:39 pm
im using my backup-up firmware for modding,my firmware version is 3.5.37...and just a while ago i also change/modded my friends mp4 player and also got same result(VOIP is locked!),and i also used his backup firmware(version 3.5.35)...but execept for that error,the player is functioning very well..
Old 27th Nov 2006, 11:08 pm
Davi, There have been a few posts about this problem and I have not heard of any way to fix it.
The last time we tried to fix the problem for someone they ended up killing their player. Fortunatly we were able to recover it but had to live with the problem.
I have a feeling that VOIP enabled players need a full firmware to set them up correctly as their are certain files not included in a dump, but this is just a theory.
Davi , i don't know how to remove the voip error message. As mentioned in the previous post of the thread that i've mentioned, there wasn't a solution to this problem either.
The only thing i can think of is that the firmware was made for voip-enabled hardware/players. And the manufacturers somehow disabled the voip function, but not removing it from the firmware.
When you reloaded the firmware, the voip disable was removed and thus the error keeps occurring.
Old 28th Nov 2006, 2:17 am
ok...at least all the function are ok and i'm happy that i've personalized my mp4 player with the help from this forum..thanks for all the replies.....more power!!!
Old 7th Dec 2006, 10:33 am
mabye u could copy the voip files from a voip enabled firmware into ur dump
Old 7th Dec 2006, 2:53 pm
Hmmm, there is a workaround for this problem, there's a tool and .doc file on drivers CD that came with ur mp4 player. I got that error every time a flashed my player with new fimware, ofc the tools for unlockin it is on CD, I did it many times and it works fine. If any1 needs it I can upload it somewhere along with original firmware for my MS Industrial MP404.
Screen locked and text "Powerkey+sideupkey unlock" sschsu Support and How To 4 3rd Feb 2008 7:08 pm
VOIP is locked need update it dboysz Support and How To 0 25th Nov 2007 6:40 pm
"VOIP is locked" pele Support and How To 2 6th Mar 2007 12:44 pm
"VOIP is locked, need update it." tankertiong77 Dead Players 3 25th Sep 2006 6:03 pm
VOIP locked? Invertebrato Dead Players 1 6th Aug 2006 3:30 am
