How to Identify the Firmware
Old 30th Dec 2006, 10:47 pm
Default How to Identify the Firmware
I have a new Mp4 player that i bought and i want to identify the type of firmware it was using. Is there any software i could use or a firmware available so that i could change the firmware of my mp4? Thanks :?:
Old 30th Dec 2006, 10:48 pm
Default Re: How to Identify the Firmware
I have those 2" Players.
Old 30th Dec 2006, 11:36 pm
darkmatter_1602, You can find your firmware details in the Settings menu of your player under Firmware Version.
Loading another firmware is not a good idea, even if they are the same version number they will most likely be completely different to your players firmware. It is also the fastest way to kill your player.
Depending on what version your player is using you may be able to theme it though.
myMP4 - please help me to identify this(chipset, firmware) angelprone Dead Players 13 23rd Sep 2009 8:19 am
Identify Firmware software version dcdna Support and How To 0 20th Aug 2009 12:14 am
Please help to identify and find firmware!! yellowmegaman Support and How To 0 1st May 2008 12:51 pm
Please help identify my mp4 Player & upgrade firmware figarow Support and How To 2 29th Nov 2007 1:30 pm
Pic of my mp4 , how do i take apart to identify firmware ver ericz123 Dead Players 4 10th Oct 2007 8:37 am
