YES 9.0.48 Firmware can be modded
Old 30th Jan 2007, 11:07 am
Default Re: YES 9.0.48 Firmware can be modded
i ddid what u wrote but after it tells me that the fw success, it restart the ipod clone and nothing happen.. i'm finding myself with me old fw~...
why does it happens?
Old 30th Jan 2007, 11:14 am
nirh216 , the "firmware update success" in the Upgrade Tool only tells you that the firmware has been successfully written into the player. It does not mean that the firmware will be compatible with your player.
Old 5th Feb 2007, 8:09 pm
what are ur serial numbers? maybe this full firmware can work on my player. probly not tho. but maybe
My 2Pac main menu
Old 15th Feb 2007, 11:57 am
Erm...guys...I am new one on this forum but i'm not a NOOBE in modding and i say: I ALREADY THEMED MY 9.0.48 firmware 3 times
And...FULL firmware can be downloaded FROM PLAYER by ATJUpload4.0-Beta-its on japan but i can include PIC with instruction
I used s1res v2.1 to edit firmware
In quetions of uploading this programs(if you TOOOOO LAZY to find it yourself ) you can mail me at PaCTaMaH7@yandex.ru
Old 15th Feb 2007, 12:05 pm
Thanks for the information ki4hou!!!
At least it answers the question for me that my mp4 player has a blank screen because of incorrect firmware.
Yes, what;s the name of the software that allows you to change the settings of your language and battery? is it s1res?
Thanks for the info once again mate
  #16 (permalink)
Old 28th Feb 2007, 1:15 am
to mod name,menu language,battery capacity,fm/am radio enabling/disabling(if hardware doesn't support it wouldn't work ;}) e.t.c USE
s1_mod
  #17 (permalink)
Old 22nd May 2007, 1:18 pm
PaCTaMaH, can you please include a picture and some detailed informations of what and how you did it?
Thank you.
  #18 (permalink)
Old 29th May 2007, 11:55 pm
hmm u tried to mod ur 9.0.48 and successful?
Onda VX 757+ clone modded firmware Hotboxx Mods and Themes 0 17th Oct 2008 2:42 pm
ankya chip can be modded or reskinned? lionblazeo Mods and Themes 0 20th Apr 2008 8:13 pm
anyone modded the firmware of their Omega V88 / V89 mp4? jsw-000 Mods and Themes 0 24th Dec 2007 12:32 am
