YES 9.0.48 Firmware can be modded
Old 14th Jan 2007, 6:33 pm
Default YES 9.0.48 Firmware can be modded
Yes, believe it or not it is possible. You will need to download a 9.0.48 FULL version from the Firmware section, since it is NOT possible to extract it from your player at this time. Be sure it is compatible with your board and chipset. The way i figured out which one worked (RISKY) for my player was to download every 9.0.48 FULL file that was listed and flash it to my player until I found one that worked (dont flame me if you brick your player, I had no problems but that dosen't mean someone else won't). If you do choose this method and flash a firmware that is incompatible, your player will just show a blank screen. As long as it will still reconnect to the computer, even though the flash drive dosen't show up, you can still flash it with another file. ALTHOUGH, IF THERE IS NO FILE AVAILABLE FOR YOUR PLAYER YOU ARE S-O-L AND YOUR PLAYER IS A BRICK. After you find a compatible firmware file use the Firmware Modify tool from S1mp3.org to edit the language and battery settings. My file was set to default to Chinese and 1.5v Alkaline, so, I needed to change it to English and 3.6v Lithium. Save the modifications and then open it with S1res and change all the images you please. After you are satisfied, save the modifications and flash your played with the modded 9.0.48 firmware and enjoy being one of the first few with a modded UI on a 9.0.48 player.
Ohh yeah I'm new to the opensource idea with an MP3 player but have over 10 years of computer experience and have owned an onsite IT business for 8 years. As I figure out and learn more I will post my findings.
Old 14th Jan 2007, 7:11 pm
Default Re: YES 9.0.48 Firmware can be modded
Just wanted to restate that the method I used could be VERY VERY risky. Try to avoid the method I used. most of the FULL versions of the 9.0.48 firmware have descriptions so try to go by that. Also, anybody know where they got the full versions from being that they can't be extracted????
Old 14th Jan 2007, 8:55 pm
ki4hou , usually the full versions comes from manufacturers or sellers. Or by using a similiar existing full firmware and merging it with your compatible dump firmware.
Old 14th Jan 2007, 9:02 pm
I had that suspicion. I just didn't know if there was another way i didn't know of extracting it from the player.
Old 16th Jan 2007, 8:26 pm
what do u mean by
"My file was set to default to Chinese and 1.5v Alkaline, so, I needed to change it to English and 3.6v Lithium" ?
can u change the amount of battery power ur getting or something?
Old 16th Jan 2007, 8:38 pm
sswajeta , some firmware modifying tools allows you to change the default settings of the player.
The battery setting does not affect the usage time significantly. tadad1 had ran a couple of tests with the various settings, but no major increase in usage time.
Old 19th Jan 2007, 5:29 pm
How do you take yours apart I have the same one and the FM Radio caused it to have a HARD ERROR now I can't use it doesn't even turn on.
I just got this thing today.
Old 21st Jan 2007, 1:11 pm
Can you send me a dump file or your full file or both because mine was pretty much DOA when I got it and I only got to use it for about 20 minutes and then it died.
Old 24th Jan 2007, 5:47 am
Hi,
I also would like the full firmware please. I found the 9.0.48 full version but I can't quite understand if it's the full version or not. I uploaded to my MP4 but I still get a black screen when I turn it on. The strange thing is that if I plug it to my PC I can see my files and use it as a normal pen drive.
What am i missing?
Old 24th Jan 2007, 8:00 am
mangi , currently your player lacks a working firmware. If those v9.0.48 firmwares do not work for you, then there is nothing much you can do about it. As the firmware extraction tool does not support any versions higher than v9.0.43 at this moment.
Onda VX 757+ clone modded firmware Hotboxx Mods and Themes 0 17th Oct 2008 2:42 pm
ankya chip can be modded or reskinned? lionblazeo Mods and Themes 0 20th Apr 2008 8:13 pm
anyone modded the firmware of their Omega V88 / V89 mp4? jsw-000 Mods and Themes 0 24th Dec 2007 12:32 am
