-   -   Battery Replacement (http://mympx.org/forum/mods-themes/36045-battery-replacement.html)
yngwie0001 16th Jan 2007 11:07 am
Battery Replacement
Is it possible to replace my current battery with an ipod shuffle battery as my players batt life is terrible?
I have a nano clone 1.5" player by the way.
Thanks in advance.
lattesurf 16th Jan 2007 11:28 am
yngwie0001 , take a look in this battery changing thread here http://www.mympxplayer.org/new-batte...ne-vt2313.html
yngwie0001 16th Jan 2007 12:09 pm
lattesurf, Thanks for your reply,I have seen this post already the thing is, is the battery mentioned in that post able to fit into my player or not?
lattesurf 16th Jan 2007 12:30 pm
yngwie0001 , it would be difficult to say whether it'll fit your player or not. You'll need to open your player and measure the maximum allowable space for the battery. Some sellers on ebay lists the battery's dimensions in their ads. Or you can ask them for the dimensions.
But i've noticed that the ipod shuffle battery usually would be able to fit most nano-clones. For the ipod nano batteries, you'll need more space.
