Nano battery replacement
Old 18th Jan 2007, 12:18 pm
Default Nano battery replacement
I would like to replace the battery in my player and have read this post:
http://www.mympxplayer.org/new-batte...ne-vt2313.html
Does anybody know if i can fit the ipod nano battery in my player as this person has done? it is a 1.5" nano clone.
I have pm'ed the person who posted the above post without reply.
I would also like to know if there are any over charging issues with using the ipod nano battery.
Thanks in advance.
Old 18th Jan 2007, 8:53 pm
yngwie0001 , you will need to open the player and measure the maximum allowed space for the battery.
Some sellers on ebay lists the replacment battery dimensions too, so you can check with it.
However, some players will fit a nano battery, while others won't. But i've found that the ipod shuffle battery would be able to fit.
There was a thread a few weeks back that a replacement battery apparently "balloned" due to some charging issues. But as long as you do not overcharge it, i guess it would be relatively safe.
Battery Replacement? ALP1987 Support and How To 4 23rd Oct 2008 4:31 pm
where to buy replacement battery? barnbug1 Support and How To 1 1st Jan 2008 12:06 am
Battery Replacement yngwie0001 Mods and Themes 3 16th Jan 2007 12:30 pm
replacement switch for 1.5" nano look-alike 000dreamsound000 Miscellaneous 3 18th Sep 2006 8:55 am
replacement battery masfud Support and How To 2 27th Jun 2006 3:28 pm
