19th Feb 2007, 4:43 pm
Re: Need help witch modifing firmware 9.0.50 and 9.0.48
Hello, i am afraid you brick you player. and becouse you have a 9.0.48 or 9.0.50 firmware you will be unable to restore until a tool for extract the frimwre will be available and then someone with a player just like you make a copy of firmware.
all the damage was done because you use a firmware not especifically designed for you player.
if you can return in warranty could try
