Firmware - changing functions / behaviors
Old 20th Feb 2007, 11:21 am
Default Firmware - changing functions / behaviors
Hello,
what I would like to know is - if anybody can change not only the skin and look of a player
(what I have here is a ROCKCHIP, but because I know that this is the cute hardest solution it could be another Chipset capable of MP4-Playback) - but also the playing-behaviour.
Letīs say things like - "not jumping back to the menu when having played the last video-file in the list" or "ony play one video-file, then not skip to the next, but pause"...
I donīt want any additonal functions, but the play-behaviors should be changed. Anybody capable of that?
Glad about your response. Thanks.
Old 21st Feb 2007, 6:47 pm
MPx-a-lolics Anonymous
thats not possible ollip. the slowness while navigation is a common problem. one thing you can do is convert all your songs to the same bitrate and avoid using lyrics files. it will speed up the navigation considerably.
since yours is a rockchip player, it muct be firmware 9.0.xx which cant be themed yet. please wait for newer versions of s1res (tool for theming) to be released
MP5 player unable to set certain functions mightymaki Support and How To 2 10th Jan 2009 6:05 am
Pearl Z white screen no functions. evimarn General Discussion - Uxcell.com 0 8th Apr 2007 5:12 pm
Adding Midi and PSF functions rldowling03 Support and How To 4 30th Oct 2006 3:55 am
1,5" Firmware Functions Marpi Mods and Themes 2 7th Sep 2006 12:48 am
Loss of functions Mythrill Support and How To 8 2nd Aug 2006 3:19 pm
