What can I do with my Sumvision SEMPRA Pro player?
Old 1st Sep 2007, 2:23 am
Default What can I do with my Sumvision SEMPRA Pro player?
Hi all. nice site
I have a Sumvision SEMPRA Pro 4GB. i did a bit of a search on site but came up with bits and bobs.
Basically i want the low down on what i can do with this mp4 player i have had it a while now and am use to hacking and modding stuff.
i seen bits on firmware and software and what rom type it is.
if all that could be given to me that would be great. i am also curious as to weather i can change the bootup icons etc etc syncing proper best software etc etc
Old 1st Sep 2007, 4:12 am
Hi wardenet,
Welcome to the site.
Being able to mod your player depends on the chipset and firmware version of your player.
If you can go into the "System" then "Firmware Information" within your player, it should tell you what firmware version you have. From there, we should be able to tell you what chipset you have on your player and what tools are available (if any) that let's you modify it.
Old 1st Sep 2007, 12:05 pm
Default Re: What can I do with my Sumvision SEMPRA Pro player?
hi m8 got the details for you
00.00.0010 firmware
2007-03-24
Old 1st Sep 2007, 4:16 pm
wardenet...
Do you have a backup of the firmware of your player?
That's for two reasons...
first, if you intended to mod your device it will be safer if you have a backup.
second, maybe you can share it with us uploading it here... it will be very useful for me as I have been looking for this firmware for some time.
Thanks in advance
PD... Sorry I miss to say that your DAP is a rockchip unit and here you'll find some tools to deal with this firmware, for instance RKLogEdit to change the logos of it.
Old 1st Sep 2007, 4:57 pm
whats the best thing to back it up with. i will be more than happy to upload it.
Old 1st Sep 2007, 5:42 pm
You back it up?...
You mean you copy the firmware that comes in a cd?...
or did you extracted it from your device? :shock:
Old 2nd Sep 2007, 8:09 am
i do not have the cd anymore i don't think.
how do i extract the fireware from the mp4.
Old 8th Sep 2007, 10:12 am
its a rockchip. there is no software available. mabye someone with the same player can send you the files off their cd.
Sumvision Opus III brianh88 General Discussion 2 17th Jan 2009 12:58 am
How do I upgrade my Sumvision Sempra Pro? Stevey Support and How To 1 13th Feb 2008 10:53 am
Sumvision Sempra WAV file will not play on PC Vimes Support and How To 0 2nd Oct 2007 11:16 am
sumvision ice800 mp4 player rkp games. louisjo Support and How To 1 28th Sep 2007 11:14 am
Sumvision K-PAC 2Gb MP3/4 Player psychokid Support and How To 2 6th Jan 2007 11:58 am
