Help update the Firmware Editor
Old 17th Nov 2007, 7:05 am
NBS NBS is offline
Oh,ok in understand now.
I think it will be better if the current function :"creat new item with selected rect" would simply add the item in the lst just like you see it in the image,so if it's relative to the start offset it should make the difference between the image offset and the start.That way will work for both sequential images and not .
Old 17th Nov 2007, 9:31 am
Default Re: Help update the Firmware Editor
The way it works in RKLogoEdit is if you want to jump over a picture for example you get a .lst entry like:-
ItemName=FM
ShortDesc=Radio
ItemDesc=FM RADIO
ItemID=940
ItemType=1
SubType=0
ItemFlag=0
ItemRect=0,0,240,320
OffSet=-1,&h11D0
whereas a sequential entry would be :-
ItemName=FM
ShortDesc=Radio
ItemDesc=FM RADIO
ItemID=940
ItemType=1
SubType=0
ItemFlag=0
OffSet=-1,0
note the difference in the line "OffSet=" , the "relative offset"
This method could be used for the dancemammal editor too to jump over pictures or only choose selected pictures.
Old 3rd Dec 2007, 7:01 am
hi dancemammal
how is goin lad
have you made any progress/updates to the editor yet
not hassling you mate, just give us a little hint as to whats goin' down
cheers
Old 3rd Dec 2007, 7:13 am
Yeah, we're all looking forward to firmware extraction so we can play a little on our players...
Old 3rd Dec 2007, 7:26 am
Hi All,
I guess it's update time,
Sorry it's been so long, my job does sometimes get in the way
Most of the work on the Editor has been completed, the rest of my time has been spent on the extractor.
I will have to split the next release into two parts
1. The Editor
2. Firmware Extractor
this will give me more time to work on the extractor.
New Features of the editor:
  • Import / Export of all images in firmware
  • Backup / Restore of players data
  • Text String Resource Editor
  • Firmware CRC32 creator
  • More LST file menu options
  • 16bit and 24bit image import
  • Export Raw Data
  • LST file header editor
Firmware Extractor (In Progress)
  • Direct USB Access
  • USB Enumeration
  • Firmware Extract to file
  • Flash Ram Scrape
I have spent many sleepless nights reading USB specs (hope you all appreciate it)
I will be releasing the Editor Soon, hopfully followed by the extractor (once I get it working)
Cheers
Dancemammal
  #16 (permalink)
Old 3rd Dec 2007, 8:16 am
Woo! three cheers for dancemammal! will be using the extractor on my sumvision KPAC pro.
  #17 (permalink)
Old 3rd Dec 2007, 8:21 am
Lets all not go mad,
It's not working just yet! time will tell,
Cheers
Dancemammal
  #18 (permalink)
Old 3rd Dec 2007, 10:06 am
We certainly do appreciate this dancemammal, you will see when the downloads section fills up with all those lovely Rockchip firmwares. :wink:
hurrah for dancemammal!
(sorry I went a bit mad there too!) ops:
  #19 (permalink)
Old 1st Jan 2008, 2:53 am
I think a lot more people would be pleased with a working extractor then upgrading the editor.
p.s. Hooray for Dancemammal!
  #20 (permalink)
Old 3rd Jan 2008, 4:11 pm
Hooray!
Yes, the extractor would be much better to have.
I'll ask again... Is there any possibility of getting SigmaTel firmware themed? I love my Meizu M6SL but i don't feel like selling my old player and that interface is UGLY. :P
Free Firmware editor v7 Support and How To 0 25th Sep 2008 3:07 pm
FirmWare Editor Ver 1.0.2.0 Dancemammal Mods and Themes 15 30th Dec 2007 11:56 pm
New Firmware Editor Version 1.0.1.0 Dancemammal Mods and Themes 21 16th Nov 2007 9:44 am
Download the New Firmware Editor From Here Dancemammal Mods and Themes 14 12th Nov 2007 5:28 am
EDITING FIRMWARE WITH HEX EDITOR! Superboto Mods and Themes 20 28th Nov 2006 4:37 pm
