Help update the Firmware Editor
  #31 (permalink)
Old 5th Feb 2008, 6:58 am
Looks like it might be possible to mod the Onda vx747 with version 1.0.1.0 of dancemammal.
I just created this small .lst file and loaded it together with v1.10 firmware to mod the palm trees background on the player.
You need to untick "Image Bit Swap" to display the picture correctly in dancemammal.
There is no option to save the firmware as .HXF so I saved it as .bin and then just renamed the extension back to .HXF
Not able to test as I don't have this player, but as long as the updater accepts the firmware changes then it should work.
// RockChip Editor File
// Editor Ver 1.0.0.0
// Created By Dancemammal 2007
//Header
Chip=JZ4740, Chinachips chipset
MName=Onda,001,
PName=VX747
Version=1.10(20080130)
DefaultOffSetB=9859288
DefaultOffSetT=(default)
OInf1=ShortDesc:VX747
OInf2=(none)
ItemCount=0
//Items
ItemName=ItemName
ShortDesc=Desc
ItemDesc=Description
ItemID=1
ItemType=1
SubType=0
ItemFlag=0
ItemRect=0,0,320,240,
OffSet=0,0
  #32 (permalink)
Old 20th Mar 2008, 6:37 am
Default Re: Help update the Firmware Editor
reasonably new to this forum... so hello all
any news on the Rockchip firmware extractor?
  #33 (permalink)
Old 25th Mar 2008, 2:34 pm
Just checking- does the editor work for v9 firmwares?
Also, what exactly is the name in downloads of the editor?
last, but not least, I was wondering if i could get a copy (preferably with comments) of the editor? if you dont want to give it out i understand, but just checking.
Thanks!
Free Firmware editor v7 Support and How To 0 25th Sep 2008 3:07 pm
FirmWare Editor Ver 1.0.2.0 Dancemammal Mods and Themes 15 30th Dec 2007 11:56 pm
New Firmware Editor Version 1.0.1.0 Dancemammal Mods and Themes 21 16th Nov 2007 9:44 am
Download the New Firmware Editor From Here Dancemammal Mods and Themes 14 12th Nov 2007 5:28 am
EDITING FIRMWARE WITH HEX EDITOR! Superboto Mods and Themes 20 28th Nov 2006 4:37 pm
