>.< Help with My OndaVX858
Old 30th Dec 2007, 8:07 am
Default >.< Help with My OndaVX858
Ok I`ve been working on this for almost half a week. The problems are:
1. When I put the USB Disk IN Nothing happens so I have to click my computer then open up the file. Then I click MP4 Player tools I Download that And It says MP3 Player tools So I said What the heck It might work with MP3 Player tools with a MP4 Player. So I went to the video converter And nothing happens I Upload a video I clicked the start button And it said Succes done Then I go on my MP4 Player and I don`t see anything in it 0.0 I Stayed up until 1:00 am at night to firgue this out and it still doesn`t work. So does anybody have a Program the one Decrisbed in the manual I could download and I don`t know how to work the themes OR THE FIRMWARE I need a manual for that to. Please help If nobody replys to this thread I guess I just have to keep searching therw the fourms. ( And by the way the picture and the desription in the manual is way differnet to the program I`m using I don`t know why thats why i came On this site to see if I could download a Onda Program that would actually work.)
Old 30th Dec 2007, 8:23 am
vx858 is a Rockchip player, you need to convert your video using aviconvertor first, then simply use drop and drop to copy to the player, for mp3's simply just drag and drop on to the player.
If you don't have aviconvertor then you can download it from this site, just rememeber to set the video resolution to 320x240, or you will get the message "file format error" on the player.
Modding & Skinning OndaVX858 Clon matuka Mods and Themes 0 5th Mar 2008 1:05 pm
Identify non english menu in ondavx858 Seraph Support and How To 1 14th Jan 2008 2:11 am
