-   -   Problem getting s1res to import firmware:nanoclone w/ 9.1.54 (http://mympx.org/forum/mods-themes/43518-problem-getting-s1res-import-firmware-nanoclone-w-9-1-54-a.html)
richardwad1 23rd Mar 2009 1:09 pm
I can't get any of the programs to download the firmware form my player. It is a new player with version 9.1.54 on it. I also don't see this new version yet on the site or anywhere for that matter. When I try it with s1res, it reads it for a minute and gives me an error message that says "Element not found."
I'd really like to get a dump of the firmware for others who may need it and also so I can make my own theme for it. Anyone have any ideas?
lolita 25th Mar 2009 12:41 am
Re: Problem getting s1res to import firmware:nanoclone w/ 9.
What's the board ID and CPU? .54 sounds very new.
richardwad1 26th Mar 2009 2:17 pm
I haven't taken it apart. I hoped to avoid that. I have all the information and error messages form all of the programs. The problem I am haivng is that it isn't recognized as valid firmware by any program because it is newer than the programs. I also have one that is 9.1.52. Here is the information I have.
qsb13_44t
9.1.54
element not found
brom version 3.0.80
boot flash type = f28c
wilson co. ltd.
open device: \\.\I:
v9-device detected!
giveio version: 3.1
open flash at cs-line 1...
flash chip: B614D5EC "HYNIX/SAMSUNG 2048MB (LBF)" (protected=0)
read...
Element not found.
s1fwx v3.1 - copyright (c)2005-2006 wiRe (http://www.s1mp3.de/)
dump s1 firmware from flash into file...
NO WARRANTY NOTE
BECAUSE THE PROGRAM IS LICENSED FREE OF CHARGE, THERE IS NO WARRANTY FOR THE
PROGRAM, TO THE EXTENT PERMITTED BY APPLICABLE LAW. EXCEPT WHEN OTHERWISE
STATED IN WRITING THE COPYRIGHT HOLDERS AND/OR OTHER PARTIES PROVIDE THE
PROGRAM "AS IS" WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESSED OR IMPLIED,
INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND
FITNESS FOR A PARTICULAR PURPOSE. THE ENTIRE RISK AS TO THE QUALITY AND
PERFORMANCE OF THE PROGRAM IS WITH YOU. SHOULD THE PROGRAM CAUSE DAMAGE TO
ANY KIND OF DEVICE, YOU ASSUME THE COST OF ALL NECESSARY SERVICING, REPAIR
OR CORRECTION.
IF YOU DONT AGREE TO THIS TERMS THEN PRESS ESC NOW!
scan for devices...
detected drives: [i]
<a>..<z> select device
<.> scan for devices
<?> display help
<~> exit program
$i
connect to device 'I:\'...
init device...
set device to f-mode...
get info from device...
ic version = 0x0000
storage info = 0x0C02, 0x0000, 0x0000, 0x0000
device = 'S1 MP3 Player'
bootflash type = 'F28C'
brom version = 3.0.80
firmware version = 9.1.54
read boot record...
detect firmware size...
error: The system cannot read from the specified device.
read flash...
write to file 'dump.bin'...
filename = 'dump.bin'
filetype = afi
md5 = 60A1880BDAF81F11310A2DCB04CAAB6B
file id = 'AFI '
vendor id = 0x6977
product id = 0x6552
version = 9.1.54
date = 00/00/0000
| BRECF28C.BIN | | 16kb | | F28C | | B | | 0FE4A38A |
| SYSINFO.BIN | | 192bytes | | | | | | 9F5D1692 |
filetype = unknown
disconnect from device...
success.
Press any key to continue . . .
repair dumped firmware file...
backup file to 'dump.bi$'...
try to repair firmware...
error: unknown firmware file, repairing file failed
s1res supports version 9 apparently, but it it isn't programmed to recognize version 9.1.xx only specific numbers. so it says it can't find it.
richardwad1 26th Mar 2009 2:19 pm
Also, i am able to extract a dump of the firmware with the new version of s1fwx, but I can;t use the repair tool on it....once again because it doesn't recognize 9.1.54 as a valid firmware. I don;t know who updates the program. if I did, perhaps I could send them the unrepaired dump to help with the updating.
gfhe 31st Mar 2009 12:59 am
I also had the problem, I bought it from taobao yesterday, I copied over 3G files to the NANO(8G nano MP4), then restart the unit, it can not work, The firmware loaded in is "QSD_1307 2008-12-31 9.1.54 2005-01-09, who can help me resolve the problem.thanks a lot.
lolita 1st Apr 2009 1:33 am
s1fwx 3.1 is old. Latest is 3.3.
There is no such "Element not found" message in either s1fwx or s1res.
Also, latest s1res is 4.0.
richardwad1 6th Apr 2009 1:31 pm
i have the newest versions....same problems
lolita 7th Apr 2009 1:15 am
Try another computer.
There is no "element not found" message in either s1fwx or s1res and if you are getting that then I strongly suggest you to do a virus/malware scan of your system. It is impossible for s1fwx and s1res to give that message.
utkuzu 30th Apr 2009 12:37 pm
can any body extract 9.1.54 and upload here ? really i need
