Originally Posted by deepakrr";p="
btw michiganfrog, have you tried using a bl-5c nokia battery with your glacier? did it fit?
also one more question, how do you find the videos on Glacier and what resolution do you use normally or prefer to use on it?
No I did not try the BL-5C although I wanted to, and I still dont know what the story is on that! I asked someone here who did use a 5C with his Glacier(?), but he said he modded the case a bit, and I have no idea what he did, and he never responded when I asked. I think someone else may have tried a 5C, but I still dont know how they did it. I also asked UXCell if their 5C would work in their Glacier, they just reeferred me to their site, and never really answered my question. The thing with the 5C's is they tend to have a higher mah and may last longer, plus they're dirt cheap.
Videos on the Glacier are very nice, especially if your coming from a 1st gen Chipod. They're not perfect though, but I did not experience the ghosting effect from my 1st gen Chipods. During fast action scenes, it may not be 100% smooth, despite no ghosting effect. Its like a sharp transition from one action scene to another, that the eye can pick up on. Nothing bothersome, and AFAIC, I have seen tv shows and movies on it, they play pretty good. The thing I dont like is you have to lower the resolution, because the crappy AMV software doesnt fully support the Glacier. If you dont, you end up with the video either stopping after a few secs, or stuttering sound, and maybe choppy video. The effect this has is sometimes, some scenes will show blockiness, due to the low res. Despite this, The Family Guy, which looks absolutely awful on the 1st gen chipod due to low res blockiness, looks much better on the Glacier.
These are the resolutions I use:
AMV SETTINGS FOR GLACIER (AMV 4.09:
Full size movie: 208 x 176 (low) image quality: middle
Partial size but high quality movie: 208 x 160 image quality: high
Widescreen movie: 208 x 144: image quality: high
