-   Reviews (http://mympx.org/forum/reviews/)
-   -   ONDA REVIEW (http://mympx.org/forum/reviews/39222-onda-review.html)
Cori 14th Nov 2007 8:09 am
Thanks for the quick reply! At the moment I'm still waiting for the manufacturers answers, hopefully they
will reply soon. The shop where I bought the pmp suggested not to experiment with the onda firmware since if I fail the upgrade I'll lose my warranty =/
bernardo.novas@gmail.com 28th Nov 2007 7:28 pm
Re: ONDA REVIEW
I bought myself the ONDA VX878 and the ONDA VX858LE for my sister,
I looked all over the internet for the bestest prices and finally seteled on mp4global.com
I have yoused them a bunch of times and quality is always great and best part was that the shpping was free.
snowfruit 20th Dec 2007 7:07 am
I have an unbranded Onda lookalike. How do I find out if its an LE? and does nay one have a link to the download of the latest firmware from onda.cn - I'm having trouble finding it with babelfish translations...?
DaremoS 20th Dec 2007 7:47 am
The only way is by opening the case. If in there is a Wolfson chip WM8750S then is no-LE... if there is an empty space it's a LE.
This is very important!!!... using wrong firmware LE or non-LE blocks the player. To recover it it's necessary to do the hardware-short-circuit-method.
snowfruit 20th Dec 2007 8:52 am
How do I get inside it, so far all i've managed to do is to rip of the polished outer edge :/
DaremoS 20th Dec 2007 9:37 am
You can also ask your seller if your player has a Wolfson DAC chip.
Anyway to open you just need to separate the case below the plastic around the device use just your nails to not damage the polished metal. there is no screws... it's snap on
snowfruit 2nd Jan 2008 2:38 am
Re: ONDA REVIEW
The vendor has told me there is no Wolfson DAC chip. So I am assuming this is an LE clone. Is there any reliable firmware available for this version and does any one have any successful experience with this player?
thecrip07 11th Jan 2008 8:30 pm
Re: ONDA REVIEW
Isnt this Onda mp4 player just a made up name or is it really an onda in china?
