-   Reviews (http://mympx.org/forum/reviews/)
-   -   Android Review:Onda vx580w (http://mympx.org/forum/reviews/45970-android-review-onda-vx580w.html)
knob 1st Jul 2011 11:53 pm
Originally Posted by Binh@MyMPx (Post 288395)
Nice photos Knob and thanks for the review.
What's the interface and navigation like between your two players? Was there any difference?
Was it pretty straight forward to use and easy to install apps?
Interface is pretty much the same on these devices, I find it very easy to use once you get the hang on it, bear in mind though that the screen is resistive touch, so not as good as say an ipod touch when using your fingers, you need a capacitive screen for smoother navigation, but they cost a lot more at the moment.
Apps are easy to download from the market, if you don't have wi-fi just use app installer or a file manager app and install from a microSd card. I prefer to keep my favourite apps on an sd card anyway it's quicker to install them that way than from the market.
If you get one of these remember it needs Android USB drivers installed to be able to drag and drop to the sdcard and flash memory.
Binh@MyMPx 5th Jul 2011 1:32 am
Thanks Knob,
My Windows 7 detects my Android PMP from JTShopOnline fine and I can just drag and copy the files onto the player's flash memory (like the old MP4 players). Just can't seem to get .apk files to play on it. Apparently my one is a 'light' version of the Android (didn't know there was such a thing) so doesn't player all .apk files either! :(
makd511 5th Jul 2011 1:48 am
have you been into setting to allow to run apk files from other locations
not all apk will run as some require certain hardware, resolution etc etc,
which player did you get
kimi 6th Jul 2011 7:06 pm
i managed to update the firmware, and gone are the chinese apps - finally
but also gone is one app that i bought thru market - now trying to contact the developer how to get the apps back without purchasing again
i oso got tis message that pops out each time i start the unit
"The application BooksProvider (process.com.android.rk.books) has stopped unexpectedly. Please try again"
