Problem with Firmware Update
Old 22nd Mar 2006, 8:11 am
Renan
Guest
Posts: n/a
Default Problem with Firmware Update
I'm updating my mp4 player model: Model MP3931 - 1.5 inch colour screen, but i install the other version (Model MP3366c (silver) - 1.2 inch colour screen). And aftter that, nothing more happens.
Do you can answer my question please?
Thank's
Renan.
Sorry My poor english.
Old 23rd Mar 2006, 12:40 am
Hi Renan,
When you say "nothing more happens", you mean when you turn on your player, it doesn't start and you get just a blank screen? You can't see anything on the display?
What happens if you plug the player into your computer? Does ur computer detect the player and can you transfer any files to it?
Old 23rd Mar 2006, 3:11 am
Renan
Guest
Posts: n/a
Default Re: Problem with Firmware Update
Does´t start than
Old 23rd Mar 2006, 3:14 am
Guest
Posts: n/a
Originally Posted by Guest";p=&quot View Post
Does´t start, and i dont have communications with the computer.
Old 23rd Mar 2006, 3:41 pm
Hi,
Looks like you might have a 'dead' player. Have a look at this post: http://www.mympxplayer.com/viewtopic.php?p=113#113
Hopefully this helps you out.
Good luck.
Old 5th Apr 2006, 12:21 pm
arish05
Guest
Posts: n/a
Hi,
I think i got a similar problem. I have this type of 1.5" mp4 player (s1 mp3):
http://211.78.161.57/gdpic/82469_100.JPG
I guess I upgraded it with the wrong player and all I get is a dead blue screen.
I cannot recover the old firmware either using the upgrade tool in mp3 utilities.
My original version was 3.2.16 Wilson Co Ltd. and I was only upgrading with another 3.2.16 version.
Any idea what went wrong?
I also tried a bunch of other firmwares...version
3.2.13, and other 3.2.16 versions but none work
I also tried dump.bin from this site but there seems to be something wrong with it. It is supposed to be something like 10 megabytes but when
I download the bin file, it says the size is only like 6kb!
Anyone know what type my player is? Type A?B?C?
Where can I find I firmware that will work or how do I recover my old one?
Thanx
Old 5th Apr 2006, 6:39 pm
Did you try this firmware? http://www.mympxplayer.com/dload.php...ile&file_id=46
That looks similar to yours. Try that.
The best way to recover your old firmware is to have had a BACKUP of it. Did you take a backup of you existing/original firmware before updating it?
Hopefully you are able to update the firmware using the link above. Or is your player 'dead' and can't be upgraded?
Problem in my player after update the Firmware baa1425 Dead Players 18 13th May 2007 8:53 am
Would FW update help my Nanoclone battery draining problem ajh Support and How To 2 29th Dec 2006 12:59 pm
Update of Firmware ajaybcd Dead Players 1 2nd Sep 2006 3:23 pm
update firmware mp4 AX moeshing Support and How To 1 6th Aug 2006 7:18 pm
problem in it’s firmware during update murka Dead Players 1 14th Jun 2006 1:33 pm
