problem with default folders
Old 21st Jul 2006, 10:35 am
Default Re: problem with default folders
yep, normal mode
Old 13th Sep 2006, 1:16 pm
Hi !
I have the same problem (normal mode).
I just can choose 3 folders.
When i try to choose another folder, i can't.
(Why is it working with only 3 folders ???)
Old 13th Sep 2006, 3:27 pm
Ok :
All folders must be "Read Only" ops:
Old 1st Apr 2007, 11:21 am
Hi!
This error occurs after you connected the player to a Mac. I noticed you're file structured and saw the .Trashes and so on...commonly known as dot-folders/files.
The special hidden dot-files files will also have the extension .mp3 but the first character of filename is ._file.mp3.
I believe the player builds a index of the files, which is the reason that it's not only possible to remove the hidden files... i've seen a XML-files from time to time.
Even though you remove these files you will not be able to set default folder.
Do like this:
- Format the device with a differerent operating system than Mac. Use filesystem FAT.
- Transfer your music from a Non-Mac computer.
- Set default folder and it will probably work much better...
Good luck!
/Woffie
Is it default that players with fw 9.0.50 have ACU7513 chip xspace Mods and Themes 2 22nd May 2007 1:13 am
Can see folders but cannot change folders Lexy78 Support and How To 10 18th Mar 2007 8:15 pm
Glacier 99-file limit, problem accessing folders weikell General Discussion - Uxcell.com 5 8th Mar 2007 6:50 pm
[solved] How to set default preferences on AMVConverter 3.68 jctoad Video related 0 17th Jan 2007 12:32 am
problem with selecting musicalbum folders Don Support and How To 11 2nd Jun 2006 8:41 am
